Recommended fluids - Pontiac GTO Forum
 1Likes
  • 1 Post By Sonoma GTO
post #1 of 5 (permalink) Old 07-01-2019, 03:28 PM Thread Starter
Quoted: 6 Post(s)
Recommended fluids
Looking for experienced drivers, GTO fluids suggestions. 65 rebuilt 389 (10-1 compression), Tri-Power, rebuilt manual trany, 10 bolt posi rear / 3:73 ratio. Completed break in and now 2k miles on second motor fluid (Delo 400 15/40 Diesel fluid, ZDP additive) Time for the third motor oil change and looking for transmission and rear end suggestions. Did I shock anyone with the diesel motor oil? Thanks for your time.
Sonoma GTO is offline
post #2 of 5 (permalink) Old 07-01-2019, 07:21 PM
Quoted: 401 Post(s)
This question has been hashed over 100 times here. You can do a Google Custom Search in the upper right hand corner. Type in "what type of oil" and see what you get.
100 people, 100 suggestions.
post #3 of 5 (permalink) Old 07-03-2019, 07:36 PM
Quoted: 119 Post(s)
I've been running diesel spec oil in my old cars for years now. No worries. I run Rotella usually, or Delo. Usually 15/40 due to my climate. The 4 speeds in these cars like a non-synthetic gear oil, 75w-90 or 85w-90 (straight 90 is no longer available and was factory fill). The rear end will need the same oil, with a bottle of limited slip additive added. DO NOT use gear oil for limited slip rear ends in your transmission....it will cause synchronizer failure.
post #4 of 5 (permalink) Old 07-03-2019, 09:34 PM
Quoted: 401 Post(s)
Apparently some reformulations and different names on the Rotella. It seems the choice pick is the Rotella T4 and not the Rotella T Triple.
Read these: https://www.bobistheoilguy.com/forum...-reformulation and https://rotella.shell.com/en_us/prod...rotection.html
post #5 of 5 (permalink) Old 07-05-2019, 01:14 PM Thread Starter
Quoted: 6 Post(s)
Thank you sir's.. Exactly what I was looking for. I know I can get 100 or 1000 different answers on the internet. After 7 months of rack time and complete engine restore, maintaining numbers matching originals, and being a novice, I'd rather take my chances here. Thanks again...
Name:	Dillon Beach Wildlife.png
PontiacJim likes this.
