Recommended Tire Pressure? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-08-2011, 12:34 AM Thread Starter
waltcoleman's Avatar
I have a 65 GTO 2dr coupe...just curious about tire pressure. Do you stick with the manufacturer specs (24psi front, 22psi back) even though these are non-stock?
I have 225/60R15's on the front, 235/60R15's on the back. I'm curious what others are doing for tire pressure. Thanks!
waltcoleman is offline
post #2 of 5 (permalink) Old 07-08-2011, 08:12 AM
68greengoat's Avatar
I run 35psi all the way around. Original specs would be too low for a radial. I would think handling/steering would be compromised along with tire wear.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 5 (permalink) Old 07-08-2011, 12:59 PM
Thumpin455's Avatar
You will hear people say to go by the placard and disregard everything else. With our old GTOs, it might not be the best idea. Even on radial tire equipped cars the pressure on the glove box door is a compromise between ride quality, handling, tread wear, and economy, and they are put in roughly that order, but always ride quality is first. They want it nice and smooth so you dont feel tar strips, and you sacrifice the other ones to get that soft cushy ride.
On the sidewall of your tire you have some information. Load capacity and max pressure, or recommended pressure on some tires. The load capacity goes up with more air pressure, and the ride gets stiffer, but you have less rolling resistance and you get better mileage to a certain extent.
I tend to run just under the max pressure, and even with 40-45 series tires (the short ones) I get even wear across the tread and long life out of them. The Eagle F1 tires I had on my 98 Formula went 70,000 miles, and the main reason I changed them was they were weather checked from sitting outside since 2005.
I go by the sidewall and I have yet to go with anything under 40psi. The ride is a bit stiffer, but the tires last, I get better mileage, and it handles great.
Thumpin455 is offline
post #4 of 5 (permalink) Old 07-08-2011, 04:06 PM Thread Starter
Cool, thanks for the feedback...makes sense. The current tires show a max psi of 35. I'll pump 'em up to 32psi and go from there.
post #5 of 5 (permalink) Old 07-09-2011, 10:42 AM
....as per tire sidewall.
Eric Animal is offline
tire pressure tamerlane57 Wheels and tires 10 06-07-2019 10:01 PM
What tire pressure? AlanSr Wheels and tires 9 11-19-2010 01:07 PM
Tire pressure PisnNapalm 1964-1974 Tempest, Lemans & GTO General Discussion 5 11-19-2010 10:14 AM
Recommended Tire csette85 Wheels and tires 15 09-23-2007 11:47 PM
Tire Pressure? 2006GTOLS2 Service, Maintenance and Technical Discussion 13 11-13-2005 02:04 AM
