Reflectix - alternate for Dynamat? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 01-26-2014, 08:48 AM Thread Starter
Reb
Reb's Avatar
I never want to "cheap out" when it comes to building a car, but am always open to less-expensive means to achieve effective results.
With that said, I see common application these days of Dynamat (did I get that name right?) for insulation and sound deadening on floorboards, firewall, etc.
Could this product, marketed by Reflectix and available at Home Depot for example, serve as a less-expensive alternative?
Insight, please?
Reb is offline
post #2 of 7 (permalink) Old 01-26-2014, 10:30 AM
I doubt that will do much as far as sound deadening, look up a product called super seal
fasterfiero is offline
post #3 of 7 (permalink) Old 01-26-2014, 03:39 PM
Quoted: 23 Post(s)
There is a product available in the roofing department at Lowes that is called peel and seal, is very similar to the original Dynamat for around $15 a roll 8"x24' i believe. Butyl/asphalt sticky base with two layers of polymer and a foil top.
Instg8ter is offline
post #4 of 7 (permalink) Old 01-26-2014, 04:39 PM
mbergin's Avatar
Quoted: 9 Post(s)
I used a product called FatMat. Worked like a charm and much cheaper than Dynamat.
Sent from AutoGuide.com App
mbergin is offline
post #5 of 7 (permalink) Old 01-26-2014, 05:27 PM
JVM225's Avatar
My friend's son used a product that he got on Ebay. It works the same as Dynamat for much less money. The kit even came with the roller and I think some other stuff for installation.
JVM225 is offline
post #6 of 7 (permalink) Old 01-27-2014, 09:07 AM
Quoted: 117 Post(s)
A friend used Frost King from Lowes on his '67. $20 a roll and it took about a roll and a half to do the car....so $35 worth total. It worked out very well. The car is cool, and extremely tight and quiet, like a much more modern car. Dynamat is way overpriced for what it is, IMO.
post #7 of 7 (permalink) Old 01-27-2014, 10:32 PM
leeklm's Avatar
x2 for FatMat.
leeklm is offline
Dynamat Hoodliner SWGOAT Exterior Discussions 0 04-27-2011 08:54 PM
front disk brake conversion: alternate cars? yousaygo 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 06-07-2010 10:11 PM
