refresh my memory... - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-15-2012, 09:36 AM Thread Starter
Quoted: 23 Post(s)
Ok Guys FINALLY got the stroker back in the garage, gonna try and get it planted today. Been a while since i did this so i may need some info along the way. First thing is the motor mounts which side gets the T tang passenger or driver, could have swore i scratched it in them but cannot see my marks. next should i fill with oil and prime on the stand before dropping it?
Instg8ter is online now
post #2 of 9 (permalink) Old 07-15-2012, 01:00 PM
Quoted: 105 Post(s)
Don't know what a T tang is....slow today, I guess. I always install engines dry. And I install 'em with the oil filter off. Very easy to bang it up on the frame.
post #3 of 9 (permalink) Old 07-15-2012, 02:20 PM
rickm's Avatar
Quoted: 5 Post(s)
if your refering to the '64-'74 V8 mounts exc. 455 , that one would be the left side or drivers side but you better make 100% sure first. rickm.
rickm is offline
post #4 of 9 (permalink) Old 07-15-2012, 05:05 PM Thread Starter
Quoted: 23 Post(s)
found my markings you are correct Rick.....motor is bolted in got frustrated with the headers and called it a day, all thats left is installing manifold and hooking up electric....and the damn headers....GRRRRRRRRRRR. have to mock up dual quads tonight to see if i need to get the small HEI set-up also need to find a low profile waterneck and wait for the progressive linkage....should be back on the road next weekend.
post #5 of 9 (permalink) Old 07-18-2012, 08:11 PM
T-tang is the left side...incase the rubber gets pulled or breaks from massive amounts of torque!!! Brian, try studding a couple of holes for the headers...especially the 4 th holes where the tight bend makes it hard to install a bolt.....works like a charm at my house! Eric
Eric Animal is offline
post #6 of 9 (permalink) Old 07-19-2012, 12:17 PM
Quoted: 105 Post(s)
Well now I know what a T-tang is!!! I'm all set!
post #7 of 9 (permalink) Old 07-21-2012, 05:33 PM Thread Starter
Quoted: 23 Post(s)
ok headers are in, accesories and fan bolted up. time to spike the dizzy, i want top dead center on 1 with both valves in the closed position for the compression stroke correct?
Heres mock-up of the duals, am gonna break it in with the single as i have to wait for my petronix and mill the water neck, also need to figure out how to shorten or link accelerator cable, any tips?
post #8 of 9 (permalink) Old 07-22-2012, 05:52 AM
Use a LOKAR cable...they custom fit...you cut to length.
post #9 of 9 (permalink) Old 07-23-2012, 10:48 PM
You've got it. Looking forward to the video!
refresh my memory on rear ends 68gtohawk8369 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 10-16-2011 10:08 AM
Old guy needs memory assist BearGFR 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 10-16-2011 09:38 AM
1966 GTO 389 Repair / Refresh Questions peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 06-12-2010 10:19 AM
Refresh my memory please! blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 11-29-2008 09:42 AM
Feeler: TCS Memory Module KPierson Interior Discussions 1 06-23-2006 04:05 PM
