remove drivers side door glass - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-06-2019, 03:16 PM Thread Starter
How do you remove the drivers side door glass on a 65 GTO coupe? Thanks GJRobbbbins
GJRobbins1951 is offline
post #2 of 3 (permalink) Old 02-06-2019, 03:33 PM
Quoted: 162 Post(s)
I am about to tackle this project this weekend.... weather permitting.... My understanding is it literally is a few nuts and best to have a helper....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 3 (permalink) Old 02-11-2019, 08:02 PM
Quoted: 162 Post(s)
Pretty straight forward -
1. remove door panel
2. raise window almost all the way up
3. remove (3) 7/16" nuts that hold the window in the frame
4. push / pull the bolts through the window base
5. remove window stop - (2) 7/16" bolts
6. roll window all the way up and carefully pry the base off and remove window
Current setup:
4 speed Muncie
cij911 is offline
remove or not remove fuel rail covers??????? pctek 2004-2006 GTO General Discussion 4 06-19-2014 06:14 PM
Need speaker grill for drivers side door RedRum 2004-2006 GTO General Discussion 2 04-19-2014 10:15 PM
