Replacement Hood - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-17-2011, 03:32 PM Thread Starter
Send a message via Yahoo to mikey gto
Replacement Hood
I need to buy a new hood for my 67 and there is a guy with a new one that he got from aimes that he dosent need now.Is there a differance from where the hood comes from as far as how good they are ?Also where would be the best place to get a disc brake kit.
mikey gto is offline
post #2 of 2 (permalink) Old 09-17-2011, 03:36 PM
As far as I know, the hood is either made by DYNACORN or GOODMARK. The vendor should tell you. I can't help with the disc brake question, as I used a "custom' WILWOOD set-up. Eric
P.S. If you use the aftermarket hood, use the aftermarket scoop insert also. The fit will be better.
Eric Animal is offline
Best replacement hood hinges? Jstreet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 04-22-2010 07:23 AM
Best Replacement Cam Kit jbranontn 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 03-14-2009 10:48 AM
