replacing 68 lemans instrument lenses - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-07-2015, 02:04 PM Thread Starter
how are the instrument lenses removed for replacement?
does the instrument panel need to be pulled or do they pop out
from the front?
KEYLO EBEIER is offline
post #2 of 3 (permalink) Old 12-08-2015, 07:46 AM
LouCabra's Avatar
I just got through replacing my dash panel. You will have to at least partially pull the dash panel forward to get to the lenses. I believe it would be more efficient to pull the whole thing out since its not much more work and you get access to give everything else a good cleaning and checkup (replace all the instrument bulbs reinforce grounds, etc).
LouCabra is offline
post #3 of 3 (permalink) Old 12-09-2015, 10:35 AM
dan woodland's Avatar
Quoted: 34 Post(s)
DITTO!!! Only way to do it right, take out the whole dash.
This isn't difinitive but it will show you wnat's back there...
https://www.gtoforum.com/f83/dans-69-...5/index24.html
I used this as a guide...
ULTIMATE PONTIAC GTO PICTURE SITE Text Topics article #36
dan woodland is offline
Replacing Instrument panel Jeffcarr Interior Discussions 2 12-03-2011 11:16 PM
replacing headliner in 66 lemans woolsey10 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 10-18-2011 03:40 PM
Replacing 1967 LeMans Convertible Top MeatShield72 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 08-03-2011 04:23 PM
67 Lemans - Brighter instrument cluster lighting? nedorama 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-31-2010 08:02 PM
70 Lemans instrument cluster HELP! docmark1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-08-2009 10:29 PM
