Reverse Lights - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-31-2007, 07:20 PM Thread Starter
Reverse Lights
Any input on it? Mine stay on all the time.
POOF is offline
post #2 of 10 (permalink) Old 10-31-2007, 07:47 PM
Devils3023's Avatar
Send a message via AIM to Devils3023
What year gto is this, a classic one or the new ones?
Devils3023 is offline
post #3 of 10 (permalink) Old 10-31-2007, 07:53 PM
Shorted reverse lamp switch on the transmission? Disconnect the switch and see if your lamps go out.
PEARL JAM is offline
post #4 of 10 (permalink) Old 10-31-2007, 07:56 PM
Sounds like the neutral safety/backup switch is bad or needs an adjustment. If your car has a console it is located on the shifter. Here are pictures of the switch for a column and console used in an automatic transmission;
05GTO is offline
post #5 of 10 (permalink) Old 11-01-2007, 05:49 AM
macgto7004's Avatar
Mine have NOT worked in 12 years!
Russ
21st Century Muscle, The Soul of a Legend!
70 Palladium Silver HT 400/AT *SOLD* Elvis has left the building.
2004 YJ M6
2008 IOM G8 GT
Secretary, Newsletter Editor, Webmaster, Susquehanna Valley GTO Tigers
http://svgto.com
macgto7004 is offline
post #6 of 10 (permalink) Old 11-01-2007, 06:08 PM Thread Starter
Lol Russ,! Its an 69 standard 3 speed Trans.
POOF is offline
post #7 of 10 (permalink) Old 11-01-2007, 07:34 PM
Here are B/U switches from Year One,
http://www.yearone.com/serverfiles/h...hid=512AA48739
05GTO is offline
post #8 of 10 (permalink) Old 11-01-2007, 09:35 PM
I got lights in the bumbers, but nothing else.
post #9 of 10 (permalink) Old 01-23-2008, 11:54 AM
VettenGoat's Avatar
Poof
Crawl underneath and look at the manual shifter linkage. There is (should be) a "3 rod connecting the reverse lever on the transmission to the backup light switch. Be careful, it is held in place by two VERY small Jesus clips. disconnect one end of the rod and then manually move the V shaped lever on the back-up light switch. Watch to see if the lights go off and on. This will help you narrow down the culprit before to tear the harnesses apart. My guess is you'll find the back-up switch is either mis-adjusted or disconnected. Best to check the mechanic causes before trouble-shooting the possible electircal causes. M&H Harnesses makes a good back up switch if it needs replacing. Mike
VettenGoat is offline
post #10 of 10 (permalink) Old 01-23-2008, 03:19 PM
67/04gto's Avatar
the switch i would say is bad
67/04gto is offline
