rocker arms - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-27-2014, 09:17 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
rocker arms
Dumb question for the day.... when the rocker arm is on the stud it is only supported by the valve and the pushrod? kinda floating free on the stud?
thanks as always
Tk
Topkat is offline
post #2 of 2 (permalink) Old 06-27-2014, 09:27 AM
Yep, that's almost right. The third point of support is the rocker ball/nut. On factory stock Pontiac rockers and studs, the factory specifies that the rocker ball nuts be torqued down to 20 lb.ft. (they bottom on the shoulders of the factory "bottleneck" studs). If you're running an aftermarket adjustable valve train with poly-locks, then the adjustment procedure is different but the rocker pivot point still provides that third point of support that controls the upward force of either the pushrod or the valve spring.
Rocker arms and bolts PisnNapalm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 52 11-01-2010 02:16 PM
what kind of rocker arms? rice eater Engine Discussions 4 05-17-2010 07:21 PM
1964 Rocker Arms colonial83 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-28-2010 10:30 PM
anyone do rocker arms yet? squrtdog50 Drive train, suspension, alignment and brakes. 13 09-03-2007 11:31 PM
Rocker arms 05_HUMBLER Service, Maintenance and Technical Discussion 21 07-04-2007 10:08 AM
