running too COOL? - Pontiac GTO Forum
post #1 of 26 (permalink) Old 08-06-2012, 01:54 PM Thread Starter
Quoted: 23 Post(s)
running too COOL?
I know this is not usually the problem with our Pontiacs but with the three core radiator and the tight clearance on the water pump divider the beast is running no higher than 165 with a 165 thermostat even when pushing it and on hot days (88). I am worried running this cool i am not getting peak efficiency on combustion and am gonna be fine tuning on wednesday should i grab a 185 stat to get the fires burning a little hotter?
Instg8ter is online now
post #2 of 26 (permalink) Old 08-06-2012, 03:02 PM
Quoted: 103 Post(s)
165 is a tad too cool, IMO. 180-195 is where you ideally want to run. As I've said, even 210-215 is actually ok. Try the hotter 'stat. You must have one hell of a cooling system! Congrats on that one, not easy to do!
post #3 of 26 (permalink) Old 08-06-2012, 04:01 PM Thread Starter
Quoted: 23 Post(s)
Thanks GeeTee i seem to remember us having this talk before and wanted to make sure, yes i have been running it through teh paces and took it on a med length drive today over a few hills and pushing it up the rev range for break-in and cannot get it to budge over 165, will grab a 185 tomorrow.
post #4 of 26 (permalink) Old 08-06-2012, 05:55 PM
68greengoat's Avatar
My bud's '68 400 runs at 165. I was shocked too. I'm right around 190.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 26 (permalink) Old 08-06-2012, 06:59 PM
Brian, I woulsd go to a 180* stat also....I always thought it was impossible to get a Pontiac to run that cool! I have a 160* stat in mine....It gets to 180-190with NO fans running...when I turn on 1 fan, it cools to 160* and stays there....if i turn on both fans....the Temp goes to 150* and the stat opens and closes.......then after a while stabilizes......I have tha IAII block (bigger cooling passages/siamese cylinder...an E-brock pump, 2000 x 2 =4000 cfm of fan, and a 1.5 inch 2 row aluminum radiator....Couldn't beleive it! Eric
Eric Animal is offline
post #6 of 26 (permalink) Old 08-06-2012, 07:14 PM Thread Starter
Quoted: 23 Post(s)
just did all of the normal stuff from the posts on here on mine, i did have the larger clutch fan and when i got the 18" shroud it would not fit so i trimmed off just enough of the fan tips to clear it with 1/8" gap. I then shimmed it to be half covering the blade and did the usual water pump mod. Other than that just a champion 3 row alum. radiator. Will post vid of the new set-up when i get it fine tuned on wed., have to rejet the 750 up as its starving for gas....<grin>. gonna break the motor in on the 750 while a friend machines the water neck down for the dual quads....then she will be able to eat.
post #7 of 26 (permalink) Old 08-06-2012, 07:31 PM
Brian, Sounds good!......just to be safe.....can you verify an accurate temp gauge....
post #8 of 26 (permalink) Old 08-07-2012, 07:40 AM Thread Starter
Quoted: 23 Post(s)
will do that with heat meter E, on my list of things to get today. man thats some tricky linkage on your carbs, i may have to have a waterneck fabbed if this one won't machine down enough (always something).
post #9 of 26 (permalink) Old 08-08-2012, 09:37 AM
Not familiar with your set up....can you mill a little off the manifold........there are other options also....
post #10 of 26 (permalink) Old 08-08-2012, 09:39 AM
The carb linkage is a bit tricky.....and that was before we put the TPS on the rear carb!!!!!.....E
How cool is this... Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-29-2012 12:12 PM
A cool kit car I would like to own GM4life The Lounge 10 05-03-2010 10:58 PM
Cool Car...Huh? jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 15 03-06-2009 12:56 AM
Cool, Cool, Coolsville. PEARL JAM The Lounge 3 04-07-2007 08:55 AM
Cool Vid YeloTXGoat38 Audio & Video Clips 3 03-24-2007 07:49 AM
