Rust Prevention Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-11-2014, 09:08 AM Thread Starter
Just needing some help on what way to prevent rust on under body. I live in Indiana and just purchased a 69 from California. I have band new floor pan and want to prevent rust. Any ideas? Thanks!
do9ck is offline
post #2 of 3 (permalink) Old 03-11-2014, 05:36 PM
Why not have the whole underside Line X'd?
I'm talking about the spray on protective bedliner. They do offer it in a can and you apply it with a spray gun or a roller. Aside from that I would say epoxy primer and a coating of chassis black.
I'm assuming of course you are talking about a driver quality car, not a chalkmark restoration.
Are you sandblasting the underside or just power washing?
post #3 of 3 (permalink) Old 03-11-2014, 06:57 PM
Quoted: 23 Post(s)
i agree, epoxy it. Used epoxy primer then satin black epoxy on mine, seals out moisture and will hold up well to stones. Have had good luck with the rustoleum epoxy in the spray can, even used the platinum to re-finish a master cylinder and even brake fluid has yet to effect it
Instg8ter is offline
Question on Valspar Anti Rust Armor speedracer25f 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-19-2012 08:01 PM
zero rust vs rust encapsulator tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-11-2011 06:07 PM
rust prevention for young goats xtranaut 2004-2006 GTO General Discussion 6 07-30-2009 05:58 PM
Corrosion Prevention GM4life Exterior Discussions 0 12-09-2007 10:13 AM
Question about rust on the headers. logicbomb Service, Maintenance and Technical Discussion 5 09-28-2007 09:45 PM
