Saginaw to m21 question - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-28-2011, 03:14 AM Thread Starter
Cpldavis37's Avatar
So, I finally pulled my 350 and saginaw out of the lemans and while doing so I started thinking. Is a Muncie m21 a direct bolt in replacement or is there a difference with the clutch linkage. When I looked at the Muncie it does not seem to have the same linkage points for the clutch pedel linkage. Maybe it will come to me when I put it in. In my head I just cant figure it out.
Was anyone ever done this conversion if so, what problems did you run into.
Cpldavis37 is offline
post #2 of 11 (permalink) Old 03-28-2011, 10:13 AM
66tempestGT's Avatar
im not sure if the input shaft splines are the same. (but i think they are) you shouldnt even have to touch the clutch linkage. just change the trans and not the bellhousing.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 11 (permalink) Old 03-28-2011, 10:18 AM Thread Starter
Cpldavis37's Avatar
I will take pics of both and post I just can't explain it
post #4 of 11 (permalink) Old 03-29-2011, 09:16 AM
67 Basket Case Restorer
Too Many Projects's Avatar
The only linkage difference is the shifter. Like Shane said, those transmissions were completely interchangable on the assembly line, depending on engine power. The clutch and all it's related linkage are the same, as is the driveshaft. Take the Sag and shifter out and plug the Muncie with correct shifter in and you're done, UNLESS, someone in the past cobbled something non-original in there...
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #5 of 11 (permalink) Old 03-29-2011, 03:15 PM
Quoted: 99 Post(s)
I agree. Should plug right in with zero issues, as stated.
post #6 of 11 (permalink) Old 03-29-2011, 03:21 PM Thread Starter
Cpldavis37's Avatar
There is a bracket that attaches to the saginaw and held in place by a cotter pin towards the front of the linkage. This bracket is a pivot point for the clutch peddle linkage. This bracket does not seem to attach to the Muncie the same way. I will add a pic of the bracket and the two transmissions today.
post #7 of 11 (permalink) Old 03-29-2011, 06:03 PM
Your clutch pivot does'nt attach to the block? You might be able to move everything to use the block pivot point.
Or go hydraulic.
post #8 of 11 (permalink) Old 03-29-2011, 06:03 PM
Originally Posted by Cpldavis37 View Post
There is a bracket that attach's to the Saginaw and held in place by a cotter pin towards the front of the linkage. This bracket is a pivot point for the clutch peddle linkage. This bracket does not seem to attach to the Muncie the same way. I will add a pic of the bracket and the two transmissions today.
That's the back drive shaft to allow the key to go into "lock" position. I believe you need to put the car in reverse, or is it 4th, to remove the key ? You will need a whole complete different shifter for the Muncie anyway and it should come with the correct bracket to hook up the back drive shaft. If you have a shifter on the Muncie now, it most likely isn't the correct one for your year/model. It may well work but you need to get the correct arm for the shaft.
Mitch
1962 Impala SS
1938 Chev coupe
post #9 of 11 (permalink) Old 03-30-2011, 07:52 PM Thread Starter
Cpldavis37's Avatar
OK i added the pics they are of the bracket and the saginaw and of the muncie. Maybe it will be more clear now that I added pics. Sorry I could not explain it better.
ID:	10716   Click image for larger version
ID:	10717   Click image for larger version
ID:	10718   Click image for larger version
ID:	10719   Click image for larger version
post #10 of 11 (permalink) Old 03-30-2011, 08:41 PM
Yep, that is the bracket for the backdrive shaft that you show in the last pic. If you had to put the trans in 4th to remove the key, you will need to get a bracket that works with the Muncie trans. If you didn't need to put the Saginaw in gear to remove the key, then the shaft had already been over ridden and you won't need the bracket for the Muncie.
Also, the Muncie has a Super Shifter, which will require major floor butchering to use and if console equipt, the console will need to be removed. I suggest calling Hurst to see what Competition Plus shifter your year and model would take and look for one. The correct linkage kit would have the back drive bracket then too.
As a side note, the throwout bearing on the Muncie is backward, if you hadn't noticed. Don't try to install it that way.
Mitch
1962 Impala SS
1938 Chev coupe
m21 4 Spd muncie in a 64 lemans with a 400? Seol21 1964-1974 Tempest, Lemans & GTO General Discussion 8 03-18-2011 10:13 AM
m21 wont go back in :/ tyler t 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 01-27-2011 05:41 PM
A\C Question (taking out) & Bumper Question Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 5 08-25-2009 08:21 PM
Saginaw, Michigan Old Town Motorfest 7/20/08 undertaker Great Lakes 0 06-20-2008 12:09 PM
