are the scoops non functional on a 69 - Pontiac GTO Forum
post #1 of 10 (permalink) Old 09-26-2013, 07:09 PM Thread Starter
hey i have a 69 tempest covertible with a gto hood, and the scoops are completely blocked off. I was wondering if this is the norm or is this someone's off purchase? If so, has anyone cut out the scoops to make them functional (I assume the scoops Are functional for the ram air, etc but what about the basic kits?
Darth Menace is offline
post #2 of 10 (permalink) Old 09-26-2013, 07:18 PM
Quoted: 23 Post(s)
RA scoops were open, Stock scoops solid. In order for the RA to be functional you need this kit.
1969 GTO Judge RAM Air III System Complete RARE | eBay
Which has proper air filter chamber gasket seal and cable operated butterfly's to close the system down in wet weather. Earlier than 68 the RA was dealer installed option and had open scoops with no closure, I cut slots in mine to keep bugs and debris out and am fabbing a pan to fit dual quads.
Instg8ter is offline
post #3 of 10 (permalink) Old 09-26-2013, 07:29 PM Thread Starter
if i cut them to make them funtional...would it run rough when cold or wet?
post #4 of 10 (permalink) Old 09-27-2013, 06:22 AM
Quoted: 23 Post(s)
yes unless you get the ram air filter set-up.
post #5 of 10 (permalink) Old 09-27-2013, 06:31 PM
you could have two sets and switch them out for the weather.
Honestly though, the "ram air" on these hoods is of questionable benefit. The scoops are located below the boundary layer of air and a cowl induction setup like the early NASCAR cars or 67 Z28's used is much more effective.
post #6 of 10 (permalink) Old 09-27-2013, 07:29 PM
Quoted: 23 Post(s)
Or just cut a big hole in your hood stick a blower, two 750 carbs and birdcatcher on it and call it a day..... Man i hope i never see a blower for a Pontiac at the swap meets, have a feeling i would be taking it home after watching those gocam vids Alky....very cool.
post #7 of 10 (permalink) Old 09-27-2013, 08:44 PM
Here ya go Instg8ter, now you can cut a hole in that extra hood ya got.
Supercharger USA - 350 400 455 Pontiac Blower Supercharger Kits for 671 871 1071 1471 Blowers - Superchargers
post #8 of 10 (permalink) Old 09-27-2013, 09:03 PM
Quoted: 23 Post(s)
drool....Better start filling my change jar at a faster rate...
post #9 of 10 (permalink) Old 09-28-2013, 07:24 AM
Originally Posted by ALKYGTO View Post
Oh man.... now you've got me thinking about buying another hood. My original still needs to be refinished from the fire.....
post #10 of 10 (permalink) Old 09-28-2013, 07:32 AM
Be aware that the "back side" of the scoop inserts are different for Ram Air cars vs. non Ram Air cars. On Ram Air cars, the inserts are "deeper", are squared-off on the back, and have two screw bosses that are used to attach the flapper door assembly. All of the inserts that come in the repro kits that I'm aware of are plastic, not metal.
In case you didn't know, the complete factory Ram Air system in 69 and up was a lot more than just open scoops. There also was sheet metal that created sort of a "chamber" around the carburetor, foam seals, a flapper door assembly connected to a dash control that could be used to close off the scoops (in the even of rain, snow, etc.) All of the pieces are available in reproduction kit form. A complete system is pricey so shop around.
Functional hood scoops '68er 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-09-2013 11:00 PM
functional ram air? Soulonfire11 Intake and Exhaust Discussions 9 11-14-2008 07:55 PM
Spoiler, functional or not. fattirewilly Exterior Discussions 33 07-28-2006 12:03 AM
2 Scoops for me.....None for you. WanaMonster 2004-2006 GTO General Discussion 8 03-18-2006 09:12 AM
Functional Hood Scoops on 05 no rice 2004-2006 GTO General Discussion 29 04-10-2005 08:41 AM
