Screeching Sounds Front End - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-25-2011, 09:16 AM Thread Starter
I've noticed that as the weather has been getting colder, my car has been making horrible screeching sounds at slow speed when car bounces up or down I suppose. Is it this because of the ball joints needing to be replaced? My mechanic made mention of it and I just wanted to get an idea for what is common with this car. 1971 Lemans 350.
Of note, I have air shocks in the rear.
NorwalkNugget is offline
post #2 of 8 (permalink) Old 10-25-2011, 10:42 AM
check your upper control arm bushings first. then lower. ball joints could squeek if you never grease them but i doubt thats it.
freethinker is offline
post #3 of 8 (permalink) Old 10-25-2011, 02:56 PM
sounds like squeaky rubber bushings to me also....if it is the BJoints they sure need grease! E
Eric Animal is offline
post #4 of 8 (permalink) Old 10-25-2011, 03:01 PM Thread Starter
Thanks guys, will check it out.
post #5 of 8 (permalink) Old 10-25-2011, 04:28 PM
even if the bushings look good make sure you check for tightness. there is an inner metal collar that rides on the cross shaft. that collar is supposed to be clamped tight to the shaft so it doesnt move by the end bolts. the arm movement is supposed to be just the rubber flexing. if that collar is loose and rides on the shaft it is a metal to metal contact and creates a nasty squeak. sometimes you can just tighten those endbolts and stop the squeak.
post #6 of 8 (permalink) Old 10-25-2011, 06:20 PM
Quoted: 102 Post(s)
Also, check the sway bar bushings. The poly bushings on my '65 groan like mad if they're not sprayed with graphite......In my experience, ball joints clunk and snap when they're worn....they don't squeak. I agree with the other guys: rubber a-arm bushings or sway bar bushings. Check the lower a-arm bushings, too.
post #7 of 8 (permalink) Old 10-27-2011, 04:55 AM
Tambo's Avatar
+1 on Eric's advice.
Tambo is offline
post #8 of 8 (permalink) Old 10-28-2011, 05:56 PM
agreed control arm bushings first.
pontiac is offline
clunking sounds georgia31501 Service, Maintenance and Technical Discussion 9 10-04-2010 12:49 PM
NOISE!! at the front of the trans or bottom reae of the motor sounds like marbels skuzzzusmcdevildog 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 12-01-2009 09:29 PM
Exhaust sounds 2004silvergoat Intake and Exhaust Discussions 9 11-03-2009 01:00 AM
Screeching while braking vance_pounders 2004-2006 GTO General Discussion 4 07-13-2009 02:49 AM
sounds like.... Blackice Intake and Exhaust Discussions 0 09-12-2007 06:03 PM
