Seatbelt question - 1967 GTO - Pontiac GTO Forum
post #1 of 12 (permalink) Old 09-07-2013, 07:20 PM Thread Starter
Hello,
I am a new member of the forum and recently acquired a 1967 GTO. It is in good shape and currently driveable, the rub is that there are no seat belts in the back seat. I have 2 questions:
1. Did GM provide seat belts out of the factory for the back seat for GTO's in 1967?
2. Regardless of the answer to question #1, where is a good place to purchase back seat belts? If GM did provide seat belts, I would very much like to purchase genuine GM or OEM seat belts and not a cheesy knock-off.
Thanks,
Tony
Beefcake77 is offline
post #2 of 12 (permalink) Old 09-07-2013, 07:48 PM
For your comfort and safety...
HMMM... Lessee. I believe they were mandatory to be installed on the front AND rear in '67. (In '65, only the front seats needed them, rears were optional). (My '56 New Yorker had front and rear "safety straps" from the factory). I assume you've had your rear seat out, and they are not there at all? Should be at least bolt holes there for them. (Bolts for those suckers ain't cheap, either). AMES performance, OPGI, or any aftermarket store should have them. As for OEM originals, you might try advertising here or on different forums, or even on ebay. Should be as common as dirt to find, as multiple millions were made.
gjones is offline
post #3 of 12 (permalink) Old 09-07-2013, 08:10 PM
jmt455's Avatar
Yes, there should be 3 sets of lap belts back there.
In addition to the restoration suppliers, I have also had great success with restraints from Morris Classic Concepts.Morris Classic Concepts | 864-987-0032
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 12 (permalink) Old 09-08-2013, 01:21 AM
Another option is in my 69 conv i put 3pts front and 5 pt harness in rear. Looks bad ass and if you have kids it's peace of mind, just get 2" shoulder straps 3s are for racing.
groovedown is offline
post #5 of 12 (permalink) Old 09-08-2013, 07:26 AM Thread Starter
Thanks for the helpful answers everyone, I didn't pull the seat yet to check, I will do that later today and also scope out eBay for replacements.
post #6 of 12 (permalink) Old 09-08-2013, 10:54 AM
SANDU002's Avatar
I never knew there were 3 sets of belts for the back seat. Thought it was only 2 sets. I don't think I have ever seen any GTO with more than 2 sets in the back.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #7 of 12 (permalink) Old 09-08-2013, 12:26 PM
Before you buy...
Beefcake, pull the lower cushion out. 99% chance they're laying right there on the floorboard, under the seat.
gjones is offline
post #8 of 12 (permalink) Old 09-08-2013, 01:33 PM
Quoted: 100 Post(s)
'66 was the first year for front and rear seatbelts. My '65 came with no seatbelts....it wasn't ordered with any. I put in front belts about 25 years ago from a wrecked car. In '66 and '67, there was no third seatbelt in the rear seat area, only two. 4 belts per car.
post #9 of 12 (permalink) Old 09-08-2013, 05:51 PM Thread Starter
I pulled the back seat and found what was left of the 2 back seat belts, prior owner cut them off and left about 4 inches of each one, not sure why. You can see in the pic. I guess a positive is that I have the original bolts to hold them in.
Now the question is do I buy GM or the Fisher Carriage logo seat belts ? The front has GM belts, but I do not know if they are original. They look too new to be original and I am not sure the prior owner bothered to research what the correct seat belt should be.
post #10 of 12 (permalink) Old 09-08-2013, 06:32 PM
expensive bolts...
Why, the stupid idiots! Why wouldn't they have just shoved them there and left them, instead of cutting them? Start spraying those bolts down with PB Blaster, or other good penetrating fluid. Douse them, then rap them with a short heavy hammer and a piece of 1"x1" (or whatever) wood block, (just once) then spray them again, and repeat with the hammer and wood, and spray. Just until they crack loose. You don't want to mess those threads up (hopefully they weren't installed cross threaded originally). Use a stout 1/2" drive ratchet or breaker bar with the proper fitting socket, and work it slowly out (in and out). They'll probably have muck in the backside, and will come out hard. Good luck.
gjones is offline
66' deluxe seatbelt restore Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 12-22-2011 02:26 PM
Seatbelt jamming xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-25-2010 03:02 PM
66 seatbelt question chevyboy91188 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-23-2009 03:26 PM
Seatbelt question blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-09-2008 09:34 AM
1967 gto suspension question ozkar_67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-07-2008 01:04 PM
