Sharp Whoosh sound after releasing throttle - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-11-2015, 01:32 PM Thread Starter
Hello guys. I recently installed a new carb and electronic ignition conversion kit and took it out for a test drive. When I punched it it I had a sharp whooshing sound after letting off the gas kind of like a turbo sound from a wastegate. I am trying to figure out what it might be. Any help is appreciated. I have a 1970 Lemans Sport with a 428.
cardinal_67 is offline
post #2 of 5 (permalink) Old 08-11-2015, 07:59 PM
Quoted: 391 Post(s)
Yep, used to get that a lot with my car. That sound is your car sucking up some Toyota or Honda up the tail pipe. Just wait until you here the crackling sound at high speeds as you burn the paint right off the doors of those you just passed.
Seriously, sounds odd, but my guess might be the clutch fan if you have one? or flex fan? You have not said if this is a problem or not, or if it affects performance.
post #3 of 5 (permalink) Old 08-11-2015, 08:22 PM
May be a vacuum port on the new carb that is not capped, at WOT vacuum goes to zero, when you let off the gas vacuum returns and may be the sound you're hearing.
05GTO is offline
post #4 of 5 (permalink) Old 08-11-2015, 08:23 PM
pjw1967's Avatar
Is the air filter seated properly on the new carb? Last time I took mine off, I didn't get it back on correctly. Is there a filter in the cover?
pjw1967 is offline
post #5 of 5 (permalink) Old 08-11-2015, 09:49 PM Thread Starter
Thanks for the reply guys. I think it might be a vacuum issue. I'll double check all hookups. The air filter is on correctly I believe. Its a really odd sound. Thanks again for your input.
Sharp whoosh sound after release throttle cardinal_67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 08-11-2015 10:11 AM
Harland Sharp rocker help...urgent Nopps Engine Discussions 5 06-09-2013 11:43 AM
Sharp turn noise front end TxSoldier6.0 Drive train, suspension, alignment and brakes. 3 07-20-2011 06:59 PM
