She broke down - Pontiac GTO Forum
post #1 of 23 (permalink) Old 03-15-2014, 07:46 PM Thread Starter
69GTOCONVLOVER's Avatar
She broke down
Hey fellow gtowners. Today was the first time she gave up on me. Lost throttle response all the sudden and now the car doesn't start anymore. Its not a gasoline problem. Maybe something to do with electricity?
Please help.
Martin
69GTOCONVLOVER is offline
post #2 of 23 (permalink) Old 03-15-2014, 07:51 PM
Ace
Ace's Avatar
Does it turn over?
Do the other electronics work? (e.g.;lights come on?)
What type of an intake system do you have?
Need more info to do any troubleshooting.
Ace is offline
post #3 of 23 (permalink) Old 03-15-2014, 08:18 PM Thread Starter
All electronics work, and it does turn over. All original, normal air cleaner etc.
post #4 of 23 (permalink) Old 03-15-2014, 08:23 PM
Quoted: 23 Post(s)
Do you have a points distributor or HEI electronic ignition? Check and see if you are getting spark to the plugs.
Instg8ter is offline
post #5 of 23 (permalink) Old 03-15-2014, 08:50 PM Thread Starter
Points distributor. Just checked, no sparks...
post #6 of 23 (permalink) Old 03-15-2014, 09:40 PM
SCG Pontiac's Avatar
If you have a tester see if you have 12 volts on the positive side of the coil with the key on. If you have nothing there start testing voltage from the battery at the starter, and coming from the ignition. Make sure the coil still has the leads tight on their posts.
SCG Pontiac is offline
post #7 of 23 (permalink) Old 03-16-2014, 10:27 AM
chuckha62's Avatar
Quoted: 18 Post(s)
Make sure the breaker plate ground didn't break. This is the little braided ground strap inside the distributer. It attaches to the breaker plate and the distributer body. As the breaker plate moves back and forth, the braid flexes (hundreds of tousands of times in its' life) and will fail eventually.
chuckha62 is offline
post #8 of 23 (permalink) Old 03-16-2014, 12:07 PM Thread Starter
There is no power coming from the coil to the distributor
post #9 of 23 (permalink) Old 03-16-2014, 01:06 PM
make sure you have 12 volts coming from the battery. Make sure you have 12 volts at the starter. Make sure you have 12 volts at the coil. If any of those are no search for why, loose wire? bad battery? wire not connecting at the ignition etc. You should be able to find the trail of voltage and see where it stops. Run a wire from the battery to the hot side of the coil to see if it will start.
post #10 of 23 (permalink) Old 03-16-2014, 01:28 PM
Quoted: 118 Post(s)
Pull the distributor cap and have someone crank the engine over while you look at the points. Are they opening and closing? If not, suspect a worn rubbing block on the points. Very possibly worn points or bad condenser. First thing I would check is the points.
Broke off backup switch! Help! rj91049 2004-2006 GTO General Discussion 7 10-09-2009 10:21 AM
Tranny Broke 05GOAT Drive train, suspension, alignment and brakes. 4 01-31-2008 03:14 AM
I think I broke my T-56 CycloneJack Service, Maintenance and Technical Discussion 17 08-09-2007 01:57 AM
Fatbitch broke....again. GTODEALER The Lounge 9 10-11-2005 01:31 PM
car broke again badtmpdgoat Service, Maintenance and Technical Discussion 0 06-10-2005 08:39 PM
