shifter ball rattle - Pontiac GTO Forum
 1Likes
  • 1 Post By GTOJUNIOR
post #1 of 5 (permalink) Old 07-29-2019, 08:08 AM Thread Starter
shifter ball rattle
Anyone find a fix to the white hurst ball shifter rattle with the Muncie tranny and hurst comp shifter. Tried teflon tape and tried tightening more against the nut No Luck. I f I remove ball and shift it does seem better?
bfulmer10 is offline
post #2 of 5 (permalink) Old 08-04-2019, 07:57 AM
Quoted: 126 Post(s)
I was just about to post a similar question...On my 65', the shift lever (4 speed manual) will really rattle a lot. The noise is annoying, but slightly resting my palm on the hurst ball is enough to stop the rattling. It seems that vibration is coming from the transmission, into the shifter base, and then up the gear shift lever. I am wondering how these came from the factory as I doubt they shook so much....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 5 (permalink) Old 08-04-2019, 02:12 PM
Just a thought try calling Crash Enterprises he makes special bushing for hurst linkage he might have a answer.Hope he can help Eric Davidson is his name.
LAL61 is offline
post #4 of 5 (permalink) Old 08-05-2019, 04:29 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
I'll assume we are talking about OE Knobs that don't have the metal insert ? These are notorious for stripping/splitting over time.
The fix for loose conditions was either replace them or affix them with some of adhesive or thread-lock. The last option is to drill and add an insert.
If your knob is the aftermarket with insert, Is the insert loose? This may require removing insert and re-gluing. I'm just not sure if this is possible.
Name:	65-66 3 OE SPD BALL 1.jpg
ID:	120639   Click image for larger version
Name:	65-66 3 OE SPD BALL 2.jpg
ID:	120641   Click image for larger version
Name:	SHIFT BALL 2.jpg
ID:	120643   Click image for larger version
Name:	SHIFT BALL 3.jpg
ID:	120645   Click image for larger version
cij911 likes this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #5 of 5 (permalink) Old 08-05-2019, 07:50 AM
Quoted: 126 Post(s)
GTOJunior - I will check, but if I remember correctly there was a metal insert.
Current setup:
4 speed Muncie
cij911 is offline
