shifting - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-27-2015, 09:24 PM Thread Starter
maktope's Avatar
shifting
Got the car back from the shop drove home no problem. Got in today fired up great went to shift wouldn't go into 2nd. Stick is in neutral won't go in any gear but when you let off clutch it's still in 1st. Under all the linkage or rods are in place clips still good. Supposed to pour tomorrow and car is broke in the street any help would be great.
maktope is offline
post #2 of 2 (permalink) Old 02-27-2015, 10:23 PM
Quoted: 106 Post(s)
Sounds like your linkage needs to be adjusted.
Pull linkage from shifter shift trans into neutral.
Put shifter into neutral line up tabs parallel using a bolt or drill bit.
Adjust rods so they slide into holes, replace washers and pins.
Test.
Goat Roper is offline
Shifting Issue's airdale171 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-26-2013 04:42 PM
Shifting points R.I.P. SVT 2004-2006 GTO General Discussion 1 05-26-2007 11:46 PM
Shifting Techniques BigUnit42 2004-2006 GTO General Discussion 2 02-23-2007 04:19 PM
Shifting The_Goat Service, Maintenance and Technical Discussion 1 03-22-2005 05:51 PM
Shifting the 6 speed zone 5 2004-2006 GTO General Discussion 25 11-07-2004 09:19 PM
