should I buy a ram air kit? - Pontiac GTO Forum
 1Likes
  • 1 Post By stich
post #1 of 4 (permalink) Old 04-13-2016, 02:10 PM Thread Starter
so I am rebuilding my engine using butlerperformance kit ect... its going to be a beast now Im wondering if I should buy a ram air kit from ebay or just leave it as is?
how much hp does a ram air kit give ?
dcparg is offline
post #2 of 4 (permalink) Old 04-13-2016, 02:55 PM
stich's Avatar
I would and will for my project. I will help a little but the "cool factor" is worth the money.
Formulabruce likes this.
stich is online now
post #3 of 4 (permalink) Old 04-13-2016, 03:09 PM Thread Starter
I seen a ram air kit on ebay for $900 , would you need to buy anything else to convert to ram air? like manifolds ect...?
dcparg is offline
post #4 of 4 (permalink) Old 06-14-2017, 11:34 PM
leeps's Avatar
Quoted: 8 Post(s)
Hi DCparg, did you get your RA figured out? I will add that I am going to do this, so yes is my answer to your question. Some kits are more complete than others and I am sure you know by now that you have to cut the hood. The hood scoop inserts are different length to mate up to the 'flapper' that opens the air flow. A real complete kit will have the heat riser that attaches to the driver's side head and sits on the exhaust manifold.
The answer to your question about the manifold is 'it depends'. I think it would look more proper to have the HO/RA style manifolds - called 'factory headers'. However, it is not necessary other than to complete the heat riser.
Like I said, you probably got your answer, but I wanted to reply with my thoughts.
Mike
Torque (tork), n: 1. The tendency of a force to rotate the body to which it is applied. 2. See also: GTO
leeps is offline
67 pontiac ram air kit? busaben 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-17-2012 07:30 AM
70 GTO Ram Air Kit Opinions 70gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 05-10-2012 10:55 AM
(ra6) ram air 6 body kit, where can i find one? How much? gTOOmuch Exterior Discussions 5 11-22-2011 03:36 PM
800 bucks, Buy the Ram Air Hood or the L/T Headers? MaxHax 2004-2006 GTO General Discussion 4 10-25-2004 04:18 PM
