Signal Bulb Socket Issue? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-03-2011, 06:24 PM Thread Starter
Hot_Rod's Avatar
I did some searching but need a quick answer... The pass side turn signal isnt working properly on the front.
The dim part of the bulb lights up when the signals on but doesnt flash on the bright side along with the dim like it should. Parking light also doesnt come on. Is it the socket itself?
I tried cleaning it with sensor cleaner but no change. and sometimes the bulb doesnt work at all. Changed bulbs too, nothing. When I wiggle the bulb it sometimes works but not 100%. OPG has 3 different versions of the socket also and need the correct one.
Thanks!
Jarred "Hot Rod" |1970 Pontiac LeMans Sport | Just a 350...
Hot_Rod is offline
post #2 of 8 (permalink) Old 03-03-2011, 07:49 PM
Try cleaning the sockets with a little emery cloth and use diaeletric grease on the bulb base.
dimitri is offline
post #3 of 8 (permalink) Old 03-03-2011, 08:40 PM
646904GTO's Avatar
Verify the ground connection with a continuity test. These cars were awful when it comes to grounding issues.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #4 of 8 (permalink) Old 03-05-2011, 12:29 PM Thread Starter
Hot_Rod's Avatar
I'll try that, thanks guys.
What are the chances of it being the socket though? I had a similar problem with another car and it was the socket itself...
Hot_Rod is offline
post #5 of 8 (permalink) Old 03-05-2011, 11:48 PM
agreed, grounding issue if both parking and turn filaments don't work. A long shot, are you using the right bulb, which is keyed to be able to go in only one way?
pontiac is offline
post #6 of 8 (permalink) Old 03-06-2011, 08:50 AM Thread Starter
Hot_Rod's Avatar
It's only the pass side signal/parking light. All my other lights work w/out issue. Even the marker light on that side. I'm using 1157's.
I mess with the bulb and it lights up like its not making good connections inside the socket itself.
Hot_Rod is offline
post #7 of 8 (permalink) Old 03-06-2011, 09:00 AM
Had the identical issues with my parking lights and chased it all over. It was a ground wire issue. check the ground wire coming out of the socket. All grounds have to be clean, take some emory paper and sand the connector and the sheetmetal it connects too and make sure the screw is'nt covered in rust or paint.
My turn signal indicators on the dash were also malfunctioning, one would stay lit all the time, after fixing the ground problem that went away too.
Good luck OP!
post #8 of 8 (permalink) Old 03-23-2011, 03:39 PM Thread Starter
Hot_Rod's Avatar
Replaced the sockets, fixed the issue. Wasnt wiring at all... The sockets were corroded and couldnt be salvaged. All my lights work now.
Hot_Rod is offline
67 Radio light bulb, heater controls light bulb? nedorama 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 09-26-2010 06:44 PM
65 ignition socket t3 bulb socket crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 11-15-2009 05:41 PM
headlight,turnlight bulb ? travy082 Exterior Discussions 1 09-20-2009 01:40 AM
headlight bulb question! travy082 Exterior Discussions 2 03-04-2009 03:01 PM
bulb numbers HoldenGTO Interior Discussions 1 11-24-2007 12:23 AM
