smog pump connections on 67 Goat - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-14-2011, 05:54 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
I think the large port goes to the AIR unit.
where does the other go?
PCV?
thanks as always
Topkat is offline
post #2 of 7 (permalink) Old 02-14-2011, 08:34 AM
Quoted: 100 Post(s)
No, it does not go to the PCV. The smaller port with the flange goes to the hose that goes to the heads. The bigger one may be missing the intake filter....I think it's the intake port, but will need to check. 1967 was a little while back, and it's hard for me to remember.....
post #3 of 7 (permalink) Old 02-14-2011, 09:32 AM
Quoted: 100 Post(s)
Topkat, I'm staring at an original copy from the PMD assembly manual, and it shows your smog pump and all the hoses, and where they go, etc. The Big outlet on the pump is indeed the intake hose, and it connects by tube to the air cleaner housing. California cars have a special air cleaner assembly. I can't figure out how to post photos on this thread to save my life, so if you PM me, I can scan this stuff and mail it to you, or even email it to you from my home PC.
Jeff
post #4 of 7 (permalink) Old 02-15-2011, 06:18 AM Thread Starter
Topkat's Avatar
thanks Jeff. Much appreciated
[email protected]
Topkat is offline
post #5 of 7 (permalink) Old 02-15-2011, 09:05 AM
Quoted: 100 Post(s)
Top, I'm going to try and scan my diagram and try to email it to you later tonight/tomorrow night (crazy busy around here). If theat does not work, I will contact you and go snail mail.....
Jeff
post #6 of 7 (permalink) Old 02-15-2011, 09:25 AM Thread Starter
Topkat's Avatar
Thank you kind Sir
Topkat is offline
post #7 of 7 (permalink) Old 02-15-2011, 09:16 PM
Quoted: 100 Post(s)
Topkat, I was able to scan and email you two illustrations from the manual. Should give you a pretty good idea of what and where. Good luck.........
Jeff
1966 GTO Smog-Pump AKA Air-Injection Reactor Engine Performance Question take5 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 07-16-2018 11:44 AM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
67 GTO smog pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-28-2010 01:20 PM
'67 GTO smog pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-06-2010 07:50 PM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
