Spark plugs and wires... - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-07-2010, 11:21 AM Thread Starter
PisnNapalm's Avatar
What do you recommend? I figure now is a good time to swap them out while I wait on the carb kit to arrive.
Thanks!
PisnNapalm is offline
post #2 of 6 (permalink) Old 10-07-2010, 12:53 PM
Jeff's Classics's Avatar
Depends on how much you went to spend I guess, and whether or not you're looking for a bling factor.
Personally, I think any good silicone wire at least 7mm or larger in diameter is good. I prefer black, for that stock appearance. AutoZone used to sell an inexpensive (~$40ish) set of black wires, 7mm I think, that I've used on a couple of V8 engines in the past. I have MSD wires on my Corvette and I like them very much.
There are a few tight squeezes around the steering column, so boot style can be important on a Pontiac. I haven't bought plug wires for a Pontiac 400 in about 20 years, hopefully someone with some recent experience can chime in on the clearance issues.
Later
Jeff
'68 GTO, 400/TH400, AC/PS/PB/PW/tilt, hideaways, Hurst dual gate
'72 442 'Vert, 350/TH350, AC/PS/PB/PW/tilt
'71 Javelin, 401/4-speed restomod
'74 Corvette, 383/4-speed, 450 hp, restomod *SOLD*
Jeff's Classics is offline
post #3 of 6 (permalink) Old 10-07-2010, 02:26 PM Thread Starter
PisnNapalm's Avatar
Bling isn't a factor for me. How about the plugs?
post #4 of 6 (permalink) Old 10-07-2010, 02:34 PM
Stock (or mostly stock) engine, I go with stock AC Delco plugs. Gap em to spec (usually .030" for points ignition) and go. Any auto parts store can give you the number if you give them the year, engine size, and maybe 2 vs 4 barrel carb. Don't waste your money on v-groove, platinum tip, or any of that other crap on an old car.
Later
Jeff
post #5 of 6 (permalink) Old 10-07-2010, 03:57 PM Thread Starter
PisnNapalm's Avatar
What if the ignition is HEI? Same gap or slightly larger?
post #6 of 6 (permalink) Old 10-08-2010, 01:12 AM
Larger.....HEI gap is 0.050" if I recall correctly...you can ask the parts guys to look up, say, a '78 Trans Am with a 400, that would have HEI, and tell you the recommended gap.
Jeff
Spark Plugs MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 02-14-2010 01:16 PM
Spark Plugs alsgto04 Service, Maintenance and Technical Discussion 7 11-04-2008 06:01 AM
Spark Plugs? NJG8GT Engine Discussions 6 02-14-2008 09:51 AM
Plugs and Wires csette85 Engine Discussions 9 07-13-2007 05:23 PM
spark plugs? wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-27-2005 06:00 PM
