Speedometer Cable ?? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 11-04-2009, 03:20 PM Thread Starter
Hi everyone, this is my first post here. I just bought a 72 GTO and I am starting the "Little things" fixes. The car is in very good condition, but not a numbers match, just a really nice driver. Transmission is a BW T-10. The original speedo cable is cut off at the firewall. Will a new cable connect to the T-10, or do I need an adapter? How does the cable route under the car to the trans? First of many questions to come.
AGETECH is offline
post #2 of 9 (permalink) Old 11-04-2009, 03:25 PM
I would think the cable would fit. They usually run on the drivers side of the tranny to the same side frame rail, up along the shift linkage and brake booster, through the firewall and to the speedo.
post #3 of 9 (permalink) Old 11-04-2009, 09:41 PM Thread Starter
How does cable route to the right side of the trans? Does it go over the top?
AGETECH is offline
post #4 of 9 (permalink) Old 11-04-2009, 09:46 PM
All the pictures of T-10 trannies I've seen have the speedo cable coming off the rear of the tranny on the drivers side. Your's comes off the passanger side?
post #5 of 9 (permalink) Old 11-04-2009, 10:10 PM Thread Starter
Yes, cable connects on passenger side. I was told that I will need an 80" cable. But I don't see an easy way to route it. Maybe thats why the old speedo cable got cut off.
AGETECH is offline
post #6 of 9 (permalink) Old 11-05-2009, 08:05 AM
I would think you would need a longer one. I just replaced one on a `82 GP with a turbo 350, (cable on the drivers side) and it was a 100" cable. Had a little extra room, but not enough to go around to the other side of the tranny.
post #7 of 9 (permalink) Old 11-06-2009, 11:56 AM Thread Starter
I saw this same question on another forum. I guess the cable goes up over the trans.
AGETECH is offline
post #8 of 9 (permalink) Old 11-07-2009, 04:19 PM
67 Basket Case Restorer
Too Many Projects's Avatar
You most likely have a Muncie trans and yes, the cable goes over the top of the trans to be long enough. There should be/ were clips screwed to the body to help hold it up.
Ames Performance lists 2 cables 79-80 inches depending on how the cable attaches to the speedo head. One screws on and the other pushes on and is held with a clip.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #9 of 9 (permalink) Old 11-08-2009, 10:04 PM Thread Starter
Trans is definately T-10, I'll have to check the cable at the speedo. That part of the cable is still there. Thanks for all the info.
AGETECH is offline
Correct size for 66 gto speedometer?? Mr66GTO 1964-1974 Tempest, Lemans & GTO General Discussion 0 05-03-2009 07:37 PM
Calibrating a Speedometer Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 02-25-2009 12:42 AM
Help With Parking Brake Cable Removal WideTrack 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 08-06-2008 06:45 PM
Digital Speedometer slow flicker?? TexasAggie 2004-2006 GTO General Discussion 3 08-16-2006 09:48 PM
need help getting the right speedometer cable gear ergo Service, Maintenance and Technical Discussion 2 05-07-2006 09:04 AM
