Speedometer cable - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-23-2012, 01:26 PM Thread Starter
joesweeting's Avatar
Speedometer cable
My speedometer cable broke in my 69 GTO. However, when I ran the numbers on my M-20 it came out if a 67. Should I order a cable for a 67, 69 or universal? Also, the cable is still in the car. I would prefer to complete the removal and install in one day, so if you know what length to get that would be appreciated. As of right now, I'm leaning towards universal since my casing is still in tac and can cut to lenght.
Thanks,
Joe
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is offline
post #2 of 7 (permalink) Old 09-23-2012, 09:50 PM
Nashville.Clay's Avatar
Not really sure. But you could cross reference the cable the m-20 is calling for and see what all years run same cable. It may be the same part number for many different years.
Nashville.Clay is offline
post #3 of 7 (permalink) Old 09-24-2012, 09:13 AM
Quoted: 100 Post(s)
Order a cable for your car. The trannies are the same dimensionally. The cars are not.
post #4 of 7 (permalink) Old 09-24-2012, 06:45 PM Thread Starter
Just went to order, the AMES catalog has the universal cable for 64-77. However, on line it has two universal kits one 64-68 and one 69-77. Do the connections vary at transmission or speedometer? Or are the both the same?
Thanks,
post #5 of 7 (permalink) Old 09-25-2012, 02:54 AM
Koppster's Avatar
FWIW, I picked up a speedo cable for my 64 at Autozone for under $15. Just matched the fittings and length. Works fine.
Koppster is offline
post #6 of 7 (permalink) Old 09-25-2012, 08:56 PM Thread Starter
Koppster,
Great idea. I will stop by AutoZone this week and pick up a couple different kits before I work on my GTO. What ever kit I don't use I'll take back. Thanks for the info.
post #7 of 7 (permalink) Old 10-27-2012, 05:24 PM Thread Starter
Koppster,
Thanks again for the idea. It was surprisingly easy to replace.
69 gto speedometer cable installation jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-04-2012 09:16 AM
Speedometer Cable? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-13-2010 11:07 AM
Speedometer Cable ?? AGETECH 1964-1974 Tempest, Lemans & GTO General Discussion 8 11-08-2009 10:04 PM
need help getting the right speedometer cable gear ergo Service, Maintenance and Technical Discussion 2 05-07-2006 09:04 AM
Speedometer was OFF! C5ORGTO Service, Maintenance and Technical Discussion 8 04-24-2006 03:55 PM
