starter - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-10-2011, 07:14 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
starter
I believe the started mounts on the drivers side?
anyone have a pic handy?
thanks as always
Topkat is offline
post #2 of 5 (permalink) Old 02-10-2011, 09:06 AM
Quoted: 117 Post(s)
Yes, and if you have an auto trans, it will most likely need to be shimmed for the proper bendix clearance with starter shims. Not always, but 95% of the time. If the gears are not set correctly, you can damage the starter drive and ring gear teeth. Also, the rearmost lower headbolt on that side should have a stud on it so you can mount the heat insulation tube that the Batt and starter cables go thru. The tube is critical to keep the wires from burning and shorting out. There is more information about the specifics of starter clearance/installation out there, and I'm sure others will chime in. Rule of thumb is to replace the shims you removed originally and go from there.....but I'm assuming you're starting from scratch. Good luck!
post #3 of 5 (permalink) Old 02-10-2011, 01:08 PM
The correct gap is 1/8" between starter bendix drive shaft and flexplate teeth. Inlinetube sells an awesome kit for this. It has the instructions sheet, spacing tool and various shims for only $8.00. GM Starter Shims Kit part # INL 10828.
Inline tube The brake plumbing experts
dimitri is offline
post #4 of 5 (permalink) Old 02-10-2011, 01:16 PM
Agree - it's important to get the gap correct. If the starter is "too tight" to the ring gear, if you're lucky it'll be so tight that the pinion on the starter can't slide into and engage the ring gear and it'll just grind. If you're unlucky, it'll engage but it will be noisy, and so tight that the pinion on the starter will very soon come apart and shatter ----- ask me how I know
post #5 of 5 (permalink) Old 02-10-2011, 08:02 PM
66tempestGT's Avatar
thanks as always
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
starter problems xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 5 10-05-2009 11:02 AM
Starter on a '66 RON66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-22-2009 11:55 AM
Is it the starter? PatrickNJ Service, Maintenance and Technical Discussion 1 07-25-2009 05:45 PM
Starter problem Aramz06 2004-2006 GTO General Discussion 7 04-15-2008 07:33 AM
Starter Replacement BobG 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-31-2007 09:40 PM
