starter bracket - Pontiac GTO Forum
post #1 of 10 (permalink) Old 06-25-2011, 12:09 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
starter bracket
afters going thru hell I finally got that [email protected]#$%^&*()_)(*&^%[email protected]#$%
starter bracket bolted to the read motor mount bolt.
Now of course the starter wont go in.
when I push the stud thru the hole the rear of the starter is at this weird angle and wont go up to mount the starter bolts
now what?
thanks as always
Topkat is offline
post #2 of 10 (permalink) Old 06-25-2011, 12:36 PM
I always believe that if the factory put it there, it belongs there.
When it comes to a starter brace, when I first bought in 1979 it did not have one. I never knew they existed until recently. 32 years and 300,000 miles later I still don't have one. I think this is one of those exceptions of to my rule of parts belonging there. So I still don't have a stater brace.
Maybe someone else can chime in on this. I would love to hear others views.
dimitri is offline
post #3 of 10 (permalink) Old 06-25-2011, 01:33 PM
I don't see how having one could hurt, but I've owned 3 66 GTOs, and 2 67 GTOs and none had a starter bracket.
Eric Animal is offline
post #4 of 10 (permalink) Old 06-25-2011, 02:36 PM
But why did they did they come from the factory like that?
Engineering wise there has to be a reason, but I never used one.
dimitri is offline
post #5 of 10 (permalink) Old 06-25-2011, 02:43 PM Thread Starter
Topkat's Avatar
LOL ..............I did it!!
finally got the sucker mounted and shimmed.
I tapped my wires on the battery and the motor turns over.
maybe it's the magick this forum exudes.........'cause almost always after airning my frustrations on line , I get the sucker.
rock on guys!!!!!
TK
Topkat is offline
post #6 of 10 (permalink) Old 06-25-2011, 03:26 PM
Quoted: 98 Post(s)
My '67 has always had one, and my '65 never has had one in the decades I have had the car. The trick is to have the bolt that holds it to the engine mount snug, but not super tight. That way, you can pivot the bracket back and forth and get the starter in and out pretty easily. At least that's what I've always done......
post #7 of 10 (permalink) Old 06-25-2011, 04:52 PM Thread Starter
Topkat's Avatar
Okay, now that I have my tube mounted to the top of the motor mount...........and my shiny new #2 cable (running thru my niffty 1200 degree tubing)........where do the wires come out from to go to the battery?
thanks as always
Topkat is offline
post #8 of 10 (permalink) Old 06-25-2011, 05:10 PM
thanks as always
Hey Kat, not sure if 67's are the same but on my 69 the cable came up from the starter, through the tube between the block and the exhaust manifold, then along the edge of the valve cover through a cable clamp that mounted to one of the front valve cover bolts as I recall, then to the front corner of the valve cover and across to the battery from there.
Oh and for future reference (now that you don't need it but it might come in handy someday) -- the trick to mounting that front starter bracket is to loosen the motor mount bolt that holds it just enough so that you can swing the bracket forward and out of the way to get the starter in. Then once you're happy with it, swing it back down and over the stud on the starter and tighten everything up.
post #9 of 10 (permalink) Old 06-25-2011, 09:28 PM
wires come out at the front of the block near PS.
pontiac is offline
post #10 of 10 (permalink) Old 06-26-2011, 11:05 AM
Quoted: 98 Post(s)
I agree with pontiac. With you're HO manifolds and the motor-mount battery tube, the cable comes up front. The routing described by Bear is accurate for '67 standard exhaust manifold applications.
AC Vent bracket SIXT5GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-30-2010 09:49 AM
AC Bracket mdilello 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-15-2007 11:04 AM
