starter selenoid connections - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-26-2011, 05:11 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
The service manual is so vague.
I know the + from the batt goes to the big pots, along with another I believe,
I have a smaller "s"
and a "p" posts.
How many wires go on these and what are they for.
thanks as always
Topkat is offline
post #2 of 4 (permalink) Old 02-26-2011, 06:04 AM
and a "p" posts.
thanks as always
the big post has the battery cable and the main power wire for the car. the s is the power from the switch to engage the solenoid, the other terminal goes to the coil to provide 12 volt power when the car is starting.
freethinker is offline
post #3 of 4 (permalink) Old 02-26-2011, 11:28 AM
Quoted: 118 Post(s)
Some of these cars only run the big batt + cable and the small S wire. The P terminal on the solenoid isn't used.
post #4 of 4 (permalink) Old 02-26-2011, 04:43 PM
likethat's Avatar
Purple wire goes to S.
67 GTO H.O. Convert 4spd
likethat is offline
PCV connections Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 02-23-2011 06:28 AM
smog pump connections on 67 Goat Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-15-2011 09:16 PM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
Starter on a '66 RON66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-22-2009 11:55 AM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
