starter shims - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-07-2011, 04:46 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
starter shims
I added what totals out to be about 3/16'' of starter shims.
now when I hit it, when the pinion retracts,it seems like its kicking the motor back the other way.
gonna try removing some...........
FRUSTRATING!
thanks
Topkat is offline
post #2 of 5 (permalink) Old 05-07-2011, 06:27 PM Thread Starter
Topkat's Avatar
I removed a 1/16 and kicked it and the motor started, but began making terrible metallic noises and was running extremely ratty.
almost seems like the pinion was being dragged along with the fly wheel and wouldnt let go.
Is this possible?
Either that or I have major problems
thanks as always
(should have stayed out of the garage today)
ps one of my bolts is "wrong" its .025 thinner
Topkat is offline
post #3 of 5 (permalink) Old 05-07-2011, 06:51 PM
The only way to corectly shim your starter is to get the kit that Inline tube The brake plumbing experts sells. It comes complete with all the shims, special measuring tool, and instructions. This kit costs only $12.00. This is the best $12 you will ever spend.
dimitri is offline
post #4 of 5 (permalink) Old 05-09-2011, 09:47 AM
jetstang's Avatar
Yep, very possible. That is what you are shimming for, shim out til it doesn't make any ill noises or binds, then it's good. To far out and it will be out of the flywheel., or damage the bendix. It's trial and error, just keep playing with it. Mine had 5 shims, I replaced the starter, used the same 5 shims and it is perfect. If you had it too close, you may have already messed up the Bendix.
The correct way to shim it is to remove the solenoid, mount the starter, engage the bendix and put a 1/16" or 1/8th drill bit between the gear of the bendix and the flywheel. When you get that, it's shimmed correctly.
Burning rubber since 1982!!
jetstang is offline
post #5 of 5 (permalink) Old 05-09-2011, 12:12 PM
Quoted: 98 Post(s)
Do what Dimitri says. Now.
starter Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 17 05-07-2011 12:34 PM
starter Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 4 02-10-2011 08:02 PM
Starter on a '66 RON66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-22-2009 11:55 AM
Is it the starter? PatrickNJ Service, Maintenance and Technical Discussion 1 07-25-2009 05:45 PM
i have to hit my starter 2 Empaler Service, Maintenance and Technical Discussion 2 09-22-2005 06:25 PM
