starter whine - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-15-2014, 07:40 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
starter whine
Since I got my motor going this time around the starter whines a bit. Once It 'locked up' and made this huge noise and I had to put the car in gear and let it roll a bit. What's puzzeling is I put it together as it was before. shims and all.
previously this never happened a bit. Perhaps there's a little 'wiggle room' when the bolts are loosened?
thanks as always
Tk
Topkat is offline
post #2 of 3 (permalink) Old 08-15-2014, 07:57 AM
allpawl66's Avatar
The starter bolts are bent a tad , try swapping them with each-other , sounds like definitely too tight need more shims . Tap the solenoid only out with 12 volts and see what the distance between the flywheel is .
allpawl66 is offline
post #3 of 3 (permalink) Old 08-15-2014, 09:14 AM
Quoted: 117 Post(s)
X2! What allpawl said.
Transmission Whine gtx76 Drive train, suspension, alignment and brakes. 1 02-21-2008 07:30 AM
Rear end whine gtoibew 2004-2006 GTO General Discussion 7 04-20-2007 08:48 AM
Differential Whine bg2m8o Drive train, suspension, alignment and brakes. 59 01-15-2007 07:37 AM
Possible transmission whine? primerGTO 2004-2006 GTO General Discussion 3 12-19-2006 08:28 PM
Rearend Whine Marty Service, Maintenance and Technical Discussion 17 10-29-2005 10:07 AM
