starting noises - Pontiac GTO Forum
post #1 of 12 (permalink) Old 06-26-2011, 06:03 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
starting noises
When my starter engages the flywheel I hear a horrendous metalic clacking noise as the motor turns over.
I changed starters hoping that was the problem.
Pinion not disengaging.......
NOT
And I know I propably don't have it shimmed properly..........
I crawled under the car and had wifey start it....... and SAW the pinion retract!!!!!!
With the cacophony continuing
WTF is going on here????????????????
thanks as always
Topkat is offline
post #2 of 12 (permalink) Old 06-26-2011, 06:27 PM
Could you have shimmed it improperly after messing with the starter bracket??
Eric Animal is offline
post #3 of 12 (permalink) Old 06-26-2011, 06:42 PM Thread Starter
Topkat's Avatar
Yes Uncle Eric.
It never has been shimmed properly......(lol)
but with the pinion retracted..the starter is in my humble opinion is not a possible problem source
thanks you
Topkat is offline
post #4 of 12 (permalink) Old 06-26-2011, 08:06 PM
Quoted: 23 Post(s)
check the clearance of the flexplate to the pinion at several points i had the same problem, it the flexplate is warped a bit it will scuff the teeth of the retracted pinion like a flint....mine was throwing sparks
Instg8ter is offline
post #5 of 12 (permalink) Old 06-26-2011, 08:32 PM Thread Starter
Topkat's Avatar
Hmmmm,,,,,,,,,,the pinion retracts about 1/4'' in front of the flex plate..but im wondering if the flex plate could be rubbing on the starter housing somewhere.......(scratches head)
To make matters more confusing, this problem wasnt evident in the first few dozen attempts at starting the car.
It just "started" happening.
Topkat is offline
post #6 of 12 (permalink) Old 06-27-2011, 11:43 AM
Before you waste any time and money, properly shim the starter
dimitri is offline
post #7 of 12 (permalink) Old 06-27-2011, 01:49 PM Thread Starter
Topkat's Avatar
It makes the noise with the motor running and the starter pinion retracted
Topkat is offline
post #8 of 12 (permalink) Old 07-02-2011, 01:04 PM Thread Starter
Topkat's Avatar
Heidy Ho from the great white north.
One of my torque convertor bolts was MISSING and the other 2 loose.
Scary huh?
All I can figure is I was scared of tightening them too tight.
Now have the correct bolts, in and lock-tited, 2 750ml bottles of Tequila, limes (despite scowls from wifey + so convenient that Napa is right next door too the state Liquor store) and crab cooking in the pot.
And no more hideous noise from the Goat.
Happy 4th to 1 and all
Topkat is offline
post #9 of 12 (permalink) Old 07-02-2011, 02:18 PM
Quoted: 103 Post(s)
Topkat, you know how to LIVE!!! No worries on the converter bolts...they are grade 8 and heavy duty, and need to be TIGHT. Happy 4th to you and yours, too!!
post #10 of 12 (permalink) Old 07-02-2011, 07:52 PM
Topkat, Nice find, that would have eventually destroyed the convertor, flexplate, and possibly more....enjoy those Blue Claws and pour me a shot of that Tequila!!!!
noises from tranny area georgia31501 2004-2006 GTO General Discussion 3 09-27-2010 07:10 PM
I am just starting Craigory2007 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-17-2010 03:39 PM
help with starting denf221 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-22-2010 08:15 AM
interior noises dustyminpin 2004-2006 GTO General Discussion 4 11-21-2006 04:45 PM
The $$$ Of Is Starting Already GNX231 2004-2006 GTO General Discussion 3 04-06-2005 08:05 PM
