Steam clean or water blast under car ? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-06-2011, 02:44 AM Thread Starter
fiesta62's Avatar
hi, i need to clean up under a 67 gto it has years of dirt and oil from a leaking main seal, i was going to use a standard high pressure water blaster, but thought maybe hireing a steam cleaner might work better, has anyone gone down this path before, any suggestions what would work best, thanks
fiesta62 is offline
post #2 of 4 (permalink) Old 11-06-2011, 10:38 AM
Quoted: 102 Post(s)
Just did mine last March, and used a pressure washer, but it was a heated one that used diesel to heat the coil. It worked very well. Wear protective gear, and eye protection. Also, watch where you point the nozzle....
post #3 of 4 (permalink) Old 11-06-2011, 02:59 PM Thread Starter
fiesta62's Avatar
thats sounds good i will look into seeing if i can hire one like that, thanks again...
fiesta62 is offline
post #4 of 4 (permalink) Old 11-06-2011, 03:12 PM
Eric Animal is offline
Steam cleaning carb, now won't start KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 34 11-03-2011 11:06 AM
To media blast or not. OrbitOrange 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 30 11-03-2010 10:16 PM
Jet Blast TexasRealtor The Lounge 1 11-08-2006 11:37 PM
A Blast to Drive! SpaceCoast 2004-2006 GTO General Discussion 5 06-20-2006 08:48 PM
