steel rims - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-26-2012, 11:28 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
steel rims
Next week I'm going down to get rims and tires (finally)
The plan hithertofore (lol) is to get cheap steel rims.
Question.....if later I want to slut the car up a bit....will Rally trim rings and hub caps fit the rims?
thanks as always...
Topkat is offline
post #2 of 8 (permalink) Old 06-26-2012, 05:22 PM
Send a message via Skype™ to Jackanapes
thanks as always...
If they are Rally II rims then yes... otherwise the great slut option is those plastic bull testicals I see on the back of some trucks around here. J/K
Jackanapes is offline
post #3 of 8 (permalink) Old 06-27-2012, 03:02 PM
Quoted: 100 Post(s)
Top, they are all different. The repro rims that Coker sells have the nubs on the center section that will hold a poverty hubcap. The lip design and off set will determine if a beauty ring will work. I recommend just getting some used mags for now (like American's or Cragar's) and go that route. Or, junkyard it. Any 14 or 15 inch 5 lug from a GM or Mopar from the '60's thru the late '70's will work. Rally II's in the 15 inch diameter can be had on the cheap, if you hunt for them a bit. Watch for wallowed out lug nut holes, though. (Raises his glass in a salute towards the Pacific Northwest....home of Salmon and crazy men with hotrodded cars)....
post #4 of 8 (permalink) Old 06-27-2012, 05:45 PM
Originally Posted by geeteeohguy View Post
Any 14 or 15 inch 5 lug from a GM or Mopar from the '60's thru the late '70's will work....
Good God geeteeohguy, you just recommended MOPAR rims to a fellow Pontiac'er . I had to quote this for posterity and may even put it in my sig.
Topkat....I'd look for some 15x7 ralley II's on your local Craigslist, they are very common and should be reletively inexpensive. Please no Mopar ralley's....They'll just slow you down lol.
post #5 of 8 (permalink) Old 06-27-2012, 06:40 PM
That's the only way to make a Mopar go fast!!
post #6 of 8 (permalink) Old 06-30-2012, 02:52 PM
...Suggest a field trip to west Coast to erase Jeff's mind with liquor! Then reprogram it....somehow!
Eric Animal is offline
post #7 of 8 (permalink) Old 07-02-2012, 12:20 PM
Quoted: 100 Post(s)
My mind's been erased so many times that I'm afraid the tape's worn out. No reprogramming. (Notice I said tape...not CD, not disc, not flash drive....just plain, old, reel-to reel TAPE...not even a cassette...that'd be too high tech for me!!)
post #8 of 8 (permalink) Old 07-03-2012, 05:21 PM Thread Starter
Topkat's Avatar
Alrighty then!, 4 trips to Les Schwab later, the Beast now sports 15x8 in rear and 15x7 in front, they had to cut away about a 1/4 of the trim in the inner rear wheel well.......and the 15x8's were hitting on the front fender.
oh ya and my front end alignment went super!
oh, pretty sure some mat ask.....tires are P245/60R-15 & P235/60R-15
looks killer, oh, theyre rally in silver
thanks as usual........
3 weeks till my inspection, insurance starts friday!
Topkat is offline
Tell Me About Steel! WideTrack 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 17 01-17-2010 11:15 AM
rust and steel wool...... asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-07-2008 12:27 PM
