Steering shaft - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-06-2019, 10:13 AM Thread Starter
Steering shaft
Sorry if this has been asked before. I'm in need of the steering shaft that connects the column to the box for my 67 Le Mans, or a good bolt on replacement. Having a heck of a time finding a stock one or which after market piece is best. A link or part number would really help. Thank you!
BBM66 is offline
post #2 of 6 (permalink) Old 02-06-2019, 12:42 PM
BLK69JUDGE's Avatar
Quoted: 72 Post(s)
1967 was a solid 1 part shaft from the steering wheel to the rag joint ...
in 68 they changed to the intermediate shaft that was removable
68 columns work in 67's
if you need the 68 intermediate shaft I have a real nice spare
Scott
2o6 465 9165
BLK69JUDGE is online now
post #3 of 6 (permalink) Old 02-07-2019, 02:50 PM
the65gto's Avatar
Quoted: 12 Post(s)
Anybody tried an aftermarket shaft? Seen one with knuckles on the steering box and coming out of the firewall. It used a square tube that comes oversize and you can trim to fit. Just looking at the possibility to bypass the rag joint as I had to "trim" the rag joint because it was knocking the headers when I turned.
the65gto is offline
post #4 of 6 (permalink) Old 02-07-2019, 06:51 PM
Quoted: 119 Post(s)
Much better to knock a dent in the header tube than compromise the rag joint that steers your car.
post #5 of 6 (permalink) Old 02-09-2019, 03:58 PM
the65gto's Avatar
Quoted: 12 Post(s)
The headers are really old. Knocking a dent might cause it to just cave in :-(. Only one side of the RJ "ticked" the header and I removed the nut ground a slight angle on it and reinstalled.
the65gto is offline
post #6 of 6 (permalink) Old 02-09-2019, 06:30 PM
BLK69JUDGE's Avatar
Quoted: 72 Post(s)
shipped
thank you for the smooth transaction
Scott
'69 GTO-Intermediate Steering Shaft Boot Clamp rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-09-2013 09:01 AM
collapsible steering shaft?? leeklm 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 10 05-08-2012 04:22 PM
68 GTO Steering Shaft output m.e.g. 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 04-17-2012 12:09 AM
65 steering shaft size?? crustysack 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 02-14-2010 05:23 PM
RE: Steering Shaft Rub PDQ GTO Service, Maintenance and Technical Discussion 10 02-27-2009 06:38 PM
