Stock Tire Sizes for 1970 GTO - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-18-2014, 09:07 AM Thread Starter
scott's6.0's Avatar
What's up guys? I'm looking to get new tires for my goat since the ones on it are 13 years old . It's currently running 215/70R15's on the front and 275/60R15's on the rear. It has the 15" rally II wheels. I know these aren't stock sizes, but I would just like a reference as to what stock sizes were. Does anyone know what the conversion of the older system would be in terms of 2xx/xxR15?
I like the way the rears look, but I'm thinking about going a little wider on the fronts, maybe 225 or 235 and dropping down the sidewall ratio to 60-65. However, I want to be sure there won't be any rubbing by going wider. The car is 100% stock as far as suspension goes.
Finally, can anyone recommend a good set of summer performance tires? It currently has BFGoodrich Radial T/A's. These tires have been great, but just wondering if anyone has input on better performing tires? I see a lot of GTO's with Goodyear Eagle 1's?? Not completely sure of the model.
Thanks for any and all input guys!
1970 GTO - Triple Black - 400 - 4-speed - Flowmaster American Thunder Exhaust
scott's6.0 is offline
post #2 of 5 (permalink) Old 05-18-2014, 09:59 AM
The stock tires on a 1970 GTO were G78-14 which is the same size as 205/75 R15. What are your front and rear wheel width's?
05GTO is offline
post #3 of 5 (permalink) Old 05-18-2014, 11:18 AM Thread Starter
scott's6.0's Avatar
To be completely honest, I'm not sure. Is there a way to check with the tires on?
post #4 of 5 (permalink) Old 05-18-2014, 12:45 PM
Here is a code chart for Pontiac wheels, the wheel code may be located next the valve stem if you have a set of original Pontiac wheels. The width of your tires are determined by the width of your wheels.
Pontiac Wheel Applications
05GTO is offline
post #5 of 5 (permalink) Old 05-18-2014, 01:24 PM Thread Starter
scott's6.0's Avatar
The rear wheels have the code "HM" so according to your link that would be a 15x7. I can't seem to find any codes on the front wheels. I do see random numbers around the valve stems, not sure what they indicate though.
Wheel and tire sizes for 65 GTO ? timmyg 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 02-02-2013 08:06 AM
Need stock tire size 1970 GTO skapegoat 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-19-2010 04:54 PM
Tire sizes dieseltweaker Wheels and tires 3 05-18-2010 10:10 AM
2005 GTO Tire Sizes Wolf12 Wheels and tires 15 02-19-2006 10:26 PM
Tire sizes Mike Kortney Wheels and tires 34 12-14-2005 05:48 PM
