Swapping the 4/7 firing order on a Pontiac - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-01-2014, 12:29 PM Thread Starter
Quoted: 367 Post(s)
Ok, always looking for new ideas and info on "traditional" Pontiacs on the web that I might incorporate on my engine build/car.
Found an interesting article on swapping the number 4/7 firing position on the engineafter reading the specs on a Pontiac race engine. Apparently it can help with cooling, crankshaft harmonics & life, and smoothness of the engine. The article can be downloaded as a PDF.
MOTOR Magazine Article | MOTOR Information Systems
I then found cams ground specially for this firing order by Howard Cams at Summit. http://www.summitracing.com/search/p...s/make/pontiac
I haven't chosen a cam yet, but have a few choices in mind. Now this puts a different option into the ring. No doubt you can get this 4/7 swap from any cam manufacturer/supplier that offers custom cams.
post #2 of 6 (permalink) Old 11-01-2014, 12:46 PM
Quoted: 102 Post(s)
Learn something every day. Looks to be a fine tune, with a bit more HP with all other things assembled to match:fuel, exhaust, etc. Most beneficial for cars/engines running at peak power for extended periods, like oval track. Still, overall benefits of long bearing life and smooth operation have to add durability over the long haul. Apparently, no down-side. And if the special camshafts aren't outrageously priced, not an expensive mod, either. Makes you wonder why this didn't come up decades ago.
post #3 of 6 (permalink) Old 11-02-2014, 02:04 AM
Red1970GTO's Avatar
Fireing Order Change Up
I read about these changes years ago (that article was written for the BBC engine). AT THAT TIME the cost involved in having a special cam ground was more expensive than the 3 to 4 HORSEPOWER that was gained was worth.
Specially ground cams may be less expensive nowadays, and the change might be worthwhile for engine life or drivability... Depending on cost: it might be something worthwhile to consider during a rebuild, but doing it to a running engine, not so much (high cost, low benefit).
Red1970GTO is offline
post #4 of 6 (permalink) Old 11-02-2014, 06:02 AM
Ford racers have done this for a while. Some Ford big blocks have a crank that works like 'normal' GM stuff (1-8-4-3-6-5-7-2) but their cylinders are numbered different. Others were running a crank like ours and seeing big power changes. Ever notice how smooth older Ford engines run? Racers decided screw that and went for power. That was over 20yrs ago. This 4/7 swap, would it make a difference in the character of the exhaust tone? The only big challenge I see in a comp application is the header configuration. Seems like (after reading that) getting headers to work with the firing order (another old idea) would result in mess of tubes under the car, if it could even be done on anything other than road race or open wheel stuff. Still a clever idea for a lot of reasons, and thanks for sharing.
666bbl is offline
post #5 of 6 (permalink) Old 11-02-2014, 08:54 PM
We had my sons 68 GTO 400 stroked to a 464 last winter.
Our engine builder did the 4/7 swap and installed a Howards cam in the stroker.
This is the cam they installed
Instead of headers we are running Ramair restorations OS round port exhaust manifolds.
Oh btw.....Our engine builder rebuilds a lot of Ford engines
Bill
bondobill is offline
post #6 of 6 (permalink) Old 11-03-2014, 07:42 AM
allpawl66's Avatar
Bill
And how does it perform ?
allpawl66 is offline
GTO won't start...not firing... offroadfury6 Engine Discussions 4 02-25-2013 05:16 AM
cylinder not firing IMCauley Service, Maintenance and Technical Discussion 6 01-03-2011 10:35 AM
389 firing order? noluck 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-19-2009 06:08 PM
1972 lemans firing points nocturn2 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-04-2009 03:32 PM
1968 firing order HELP wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-19-2006 06:10 PM
