sway bar - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-09-2011, 12:03 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
sway bar
Mounting my sway bar................
Everything is way loose,the wheels are off the car and the lower control arms are sitting on jack stands.
STILL............it don't look right.
Are the control arm bolts supposed to sit so close to the upper ball joints?
I kinda know I need to wait till the car is sitting on the wheels to tighten everything down.
But how does one properly align the front bushings?
thanks as always
Topkat is offline
post #2 of 3 (permalink) Old 04-09-2011, 12:43 PM
Not to worry - that's how they look when the suspension is unloaded. When you get it on the ground with all the weight on it, that's the time to tighten it up.
post #3 of 3 (permalink) Old 04-09-2011, 12:58 PM Thread Starter
Topkat's Avatar
TY Sir...............
Topkat is offline
Front sway bar bushings Gremlin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-18-2010 02:09 PM
Rear Sway Bar CTCarGuy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 11-17-2009 04:24 PM
Sway Bar Links? PEKO Drive train, suspension, alignment and brakes. 1 09-07-2007 09:09 AM
Bent Sway Bar Endlinks Groucho Drive train, suspension, alignment and brakes. 1 09-16-2006 01:04 PM
Sway bar dgoat4me 2004-2006 GTO General Discussion 6 01-02-2006 06:05 PM
