Tachometer 66 gto - Pontiac GTO Forum
post #1 of 8 (permalink) Old 02-01-2014, 01:45 PM Thread Starter
Tachometer 66 gto
I have a 66 gto 4 speed is the tach on the hood or suppose to be next to speedometer neither on mine please advise thanks dman
Dmangto is offline
post #2 of 8 (permalink) Old 02-01-2014, 02:40 PM
1967 was the first year for the hood mounted tach.
post #3 of 8 (permalink) Old 02-01-2014, 02:59 PM
Quoted: 117 Post(s)
If you have the rally dash option, the tach would be next to the speedometer. Not so if you have the standard dash.
post #4 of 8 (permalink) Old 02-01-2014, 03:06 PM Thread Starter
Thanks for your help I want a tach where would you suggest I install there is room next to speedo it looks like a sticker. Thanks again
Dmangto is offline
post #5 of 8 (permalink) Old 02-01-2014, 03:08 PM Thread Starter
I must have standard dash should I upgrade dash or just install tach in the vacant hole next to speedo. Thanks again for your help
Dmangto is offline
post #6 of 8 (permalink) Old 02-01-2014, 04:57 PM
Quoted: 117 Post(s)
To upgrade the dash you need a rally cluster ($350-500) and a different wiring harness/adapter section. You can install a factory repro tach in the blank housing, or leave it as--is and install a Sun or other period correct tach on the steering column. Column mounted tachometers were common back in the day, and work just fine. (actually more accurate than the original in-dash tach.
post #7 of 8 (permalink) Old 02-01-2014, 10:16 PM
leeklm's Avatar
So the wife did nothing but complain about the $30 tach mounted on my steering column since the factory dash tach was not working. So $225 later, my factory tach is rebuilt and just got it all back together. While I was at it, spent another $100 to have the factory temp gauge fixed. I will need to remind the wife of this when she complains about the money I spend on the car...
leeklm is offline
post #8 of 8 (permalink) Old 02-01-2014, 10:57 PM Thread Starter
Thanks again for your time and experience
Dmangto is offline
68 GTO Dash Tachometer tom miller 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 04-15-2013 09:09 PM
1965 GTO - Tachometer Needle Replacement Chips 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 04-17-2012 07:56 AM
1965 GTO tachometer help needed?? d.reese 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 08-10-2009 06:34 PM
