Tail light rubber gasket - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-06-2017, 07:55 AM Thread Starter
alanmay0's Avatar
Could someone please tell me which side of the rubber tail light gasket goes towards the light? This gasket has a groove in it so it is design to go on a certain way. Need to know that way.
thanks
alan
Alan
alanmay0 is offline
post #2 of 2 (permalink) Old 09-06-2017, 06:21 PM
Have not examined a pair of reproduction '67 TL gaskets in a long time, & the mfg may have changed. In examining a pair of original '67 TL assemblies this afternoon, the housing where the gaskets glueon are slightly tapered outwards. My thought is to ck the repro gaskets, if the outer edges are cut at a 90 degree angle, & the groove you have mentioned is on the face of one side of the gasket, then put the side with the groove towards the TL lense. Don't want a recess that could possibly hold moisture up against the sheet metal tailpanel. Originally as built, 50 years ago, there were no epoxy primers used on the back side of the tail panels, imho, a product that at the minimum eally needs to be used in that area before paint.
tail light mgrig 1964-1974 Tempest, Lemans & GTO General Discussion 12 04-30-2016 06:20 PM
'66 GTO head light switch/ tail light problem trialsmm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-25-2016 01:22 AM
Light up the darkness: aftermarket head/tail light options Orion88 1964-1974 Tempest, Lemans & GTO General Discussion 7 01-17-2014 10:17 PM
1965 GTO Backup Light Gasket Chips 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-11-2013 09:12 AM
tail panel / tail light bezel ideas 44070dart 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-27-2012 02:59 PM
