Testing Blower Motor Resistor - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-16-2017, 10:25 AM Thread Starter
alanmay0's Avatar
I am trying to figure out why I only get two speeds on my AC/blower motor. I am wondering if anybody can tell me the correct way to check the resistor that sets on top of the AC blower housing. Everything looks good when I remove it for inspection. There are what looks like only two resistors. One is a long wire with no coil to it at all and then there is one with many coils in the wire. When I check an ohm meter to the ends of each resistor wire there shows to be continuity for both the resistors. So they should be good.
Also what speeds to these two resistors represent?? This is a factor AC car so it should have 4 speeds. I am only getting two.
So for now just want to know if I am checking the resistors correctly and what two speeds these resistors represent.
thank you always in advance
Alan
alanmay0 is offline
post #2 of 2 (permalink) Old 11-16-2017, 02:09 PM
Quoted: 9 Post(s)
Hello,
I have attached a diagram with the resistor values in it. As I recall, the resistor takes care of the first three speeds (low, med, and Med-hi). Hi speed is controlled by the relay that just bypasses the resistor and provides full voltage to the motor. Hope this helps.
Armand
Name:	schematic for heater wiring 1969 pontiac.jpg
ajluzi1957 is online now
68 blower motor help joedee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-31-2013 08:35 PM
blower motor 68GTO4004Spd 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-21-2011 07:14 PM
1972 where's the blower motor? jeremymac 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-01-2010 01:06 AM
Heater Blower Motor Joshua42007 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-05-2009 09:50 AM
