Th400 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-23-2010, 08:49 PM Thread Starter
Th400
My '68 GTO has a TH400, which shifts as it should. It is smooth w partial throttle, & chirps the tires at WOT. Feels good!
However, it "freewheels" in 2nd gear. Is that normal, and if not, what would cause it?
It decelerates in 1st and 3rd, but just disengages in 2nd when I let off the gas.
dhinnah is offline
post #2 of 4 (permalink) Old 10-24-2010, 02:12 PM
jetstang's Avatar
If it did it in all gears, I would say it's the vacuum modulator. I don't know, probably ready for a rebuild or something is sticking in the tranny. Throw some Lucas tranny stuff in it, maybe it will free it up.
Burning rubber since 1982!!
jetstang is offline
post #3 of 4 (permalink) Old 10-24-2010, 04:43 PM
Mine does none of the mentioned even when shifting through the gears. Even when the transmission was abused and worn out it did none of the above.
You should be able to feel the power from one gear to another. Total rebuild is in the 5-600 range.
post #4 of 4 (permalink) Old 10-24-2010, 05:43 PM
Quoted: 117 Post(s)
Does it freewheel when you put it in manual 2nd? If so, it could be the band or the accumulator piston that applies the band....lack of fluid pressure, burnt band, etc. Lack of pressure to the piston causes slippage and burn out. If it freewheels at all times, it could also be a one way sprag gone bad. How's the fluid? Burnt or clean? I'm afraid at least a partial teardown and inspection may be needed.
TH400 no movement kjk990 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 10-06-2010 07:45 PM
What to ask for my 455 and th400? 67goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 8 08-09-2009 05:51 PM
TH400 question teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-25-2009 10:21 AM
TH400 rebuild Face 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 02-08-2009 07:36 PM
2spd. powerglide to th400 dtroit 1964-1974 Tempest, Lemans & GTO General Discussion 4 11-03-2008 07:41 AM
