TH400 Tranny - Pontiac GTO Forum
post #1 of 9 (permalink) Old 10-18-2011, 11:47 PM Thread Starter
kilkm68's Avatar
TH400 Tranny
I've got a '68 Convertible with a Jim Butler 474 in it. The previous owner had changed the tranny out and was using a 200 4R built for raceing but now it's starting to slip. I don't plan on racing it at the strip and want to put the TH400 back in it. I just won one on ebay out of a '69 goat. Any ideas about drive shaft modifications I'm going to have to make? Haven't picked up the tranny yet so I'm not sure if it's physically longer than the 200 4R that's in it. Any one ever done this tranny swap?
kilkm68 is offline
post #2 of 9 (permalink) Old 10-19-2011, 02:23 AM
likethat's Avatar
200R4 uses the 350 drive shaft but the 400 mount location. The 200R4's yoke is smaller same one as the 350. So a 400 drive shaft is needed or yours changed over to the right front yoke and length.
67 GTO H.O. Convert 4spd
likethat is offline
post #3 of 9 (permalink) Old 10-19-2011, 10:39 AM Thread Starter
kilkm68's Avatar
Thanks a lot, I new someone here would know! I'll start looking for a drive shaft.
kilkm68 is offline
post #4 of 9 (permalink) Old 10-19-2011, 10:59 AM Thread Starter
kilkm68's Avatar
I've found a 31 spline yoke for a BOP TH400. Also a complete drive shaft. Is the yoke all I need or do you know if the 350 and 400 shafts are diffrent lengths? I think the drive shaft may have came out of a Buick GS. Know if they used the same saft in the GS/GTO?
kilkm68 is offline
post #5 of 9 (permalink) Old 10-19-2011, 01:21 PM
likethat's Avatar
GS 400TH shaft should be same drive shaft as GTO 400TH or any other Abody with a 400TH, I believe from 68 to 72. Someone correct me if I am wrong.
likethat is offline
post #6 of 9 (permalink) Old 10-19-2011, 01:23 PM
likethat's Avatar
I would bet you could get yours redone at a drive shaft shop for a few hundred bucks.
likethat is offline
post #7 of 9 (permalink) Old 10-19-2011, 01:36 PM
Consider having a new one made. I got mine from Spohn Engineering and am very happy with it.
post #8 of 9 (permalink) Old 10-19-2011, 02:06 PM
Quoted: 103 Post(s)
X3. New driveshafts are not expensive, and will not be bent or out of true as a boneyard find could possibly be.
post #9 of 9 (permalink) Old 10-19-2011, 03:50 PM Thread Starter
kilkm68's Avatar
Think all I will have to do is change the yoke or are the shafts different lengths? Was planning on taking it to a shop and having it balanced, I just want to make sure the drive shaft that is in the car now with the 200 4R is not too short before I go and buy the new yoke for it. Starting to collect parts now for winter projects. Snows just around the corner I'm afraid, about time to put the ragtop away for her winter nap!
kilkm68 is offline
TH400 Converter jmurtap 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 21 07-23-2014 01:14 AM
Th400 dhinnah 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-24-2010 05:43 PM
What to ask for my 455 and th400? 67goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 8 08-09-2009 05:51 PM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 08:23 AM
