throttle cable - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-07-2011, 07:41 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
throttle cable
Note the weird angle of my throttle cable.
when i hooked it up it was about 3/8'' to short, and as I pulled on the cable a bit I felt the pedal going down a little.
when we ran the car, there wasnt enough pedal to open the secondaries.
I can move the cable to the inside of the mounting point. (there is no other place!) it almost seems I may have to drill thru the bracket and mount it on the far inside.
Very weird!!!!
we have reaffirmed here why after market stuff sucks!!!
Thank you
Tk
Topkat is offline
post #2 of 3 (permalink) Old 10-09-2011, 02:25 PM
Quoted: 103 Post(s)
Photos, TK? As a side note, the repro throttle cables have issues: grinding, hanging up, sticking, and incorrect length have all been reported. Run into this myself on a friend's '67.
post #3 of 3 (permalink) Old 10-09-2011, 08:54 PM
I got a 36 inch lokar on a jegs brand bracket, had to modify the gas pedal slightly but one I cut the Lokar to fit it works perfectly, no bind and smooth operation. Also the throttle cable bracket is also adjustable
g750r is offline
Sticky Throttle Cable on 67 Lemans - thoughts? nedorama 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-19-2011 09:43 PM
Throttle cable issue injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-30-2011 01:09 PM
throttle cable Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-06-2011 04:25 AM
69 Throttle Cable question with picture 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-21-2010 08:39 PM
ram air throttle cable bracket my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-22-2006 11:03 PM
