timing cover seal - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-12-2011, 03:56 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
timing cover seal
Is there any special trick to installing a new TC cover seal?
thanks forever!
Topkat is offline
post #2 of 5 (permalink) Old 01-12-2011, 04:08 PM
Put a little bit of RTV sealant on the metal face and the face of the timing cover where it presses in. Use large socket and start tapping easy until it gets started evenly. Don't let it get started crooked or pop it out and try again. You'll get it.
Did you order a 3/4 windage tray? Use grade 8 bolts to put them in.
dimitri is offline
post #3 of 5 (permalink) Old 01-12-2011, 05:28 PM Thread Starter
Topkat's Avatar
Yes I did dimitri and I will ty.
'Tis the kind that mounts to the small holes on #2 & #4\
got my valley pan on it's way too...........
mwaaaaaaaaaaaaaaa!!!!!!
Topkat is offline
post #4 of 5 (permalink) Old 01-13-2011, 09:34 AM
Quoted: 118 Post(s)
Topkat, when you get the cover on, be SURE to set the clearance of your water pump divider plate. It's important.
post #5 of 5 (permalink) Old 01-13-2011, 10:14 AM
A 2x4 and a BFH works good. Be sure to lube the inside of the lip seal with some grease after you install it in the cover and before you install on the block.
66 owners - is there a seal between the body and the taillight cover? torpedo51 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 10-29-2010 07:12 AM
67--69 timing cover question bobby326 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 10-09-2010 03:57 PM
timing chain cover question clarkaim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 09-11-2009 09:22 AM
