Tire pressure - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-18-2010, 11:38 AM Thread Starter
PisnNapalm's Avatar
Tire pressure
What tire pressure should I have in my '67?
The reproduction manual I have talks about 4ply and 8ply tires. What about modern radials though?
I figure somewhere around 32 pounds should be good. What do you all run in yours?
PisnNapalm is offline
post #2 of 6 (permalink) Old 11-18-2010, 12:16 PM
Run whatever the tire manufacturer / tire shop recommends. The original factory specs assumed the tires would be the factory-supplied tires.
post #3 of 6 (permalink) Old 11-18-2010, 02:38 PM Thread Starter
PisnNapalm's Avatar
I checked the pressure and it was 33 pounds. That engine must be wicked heavy because the fronts bulge so much more than the rears.
post #4 of 6 (permalink) Old 11-18-2010, 02:48 PM
IMO: 32-35 psi. In the "olden days" I used the psi on the tire as a guide.
post #5 of 6 (permalink) Old 11-18-2010, 04:14 PM
68greengoat's Avatar
Fronts will always bulge more because of the weight of the motor. May want to go up to the tires max rating(guessing 35psi?) and watch your tire wear. If the center of the tire starts wearing quicker than the edges, lower the pressure. If the edges wear quicker, increase the pressure(Don't exceed tire rating). If the tire wears evenly, perfect!
I run 35 with my BFG T/A's. Seem to wear evenly....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #6 of 6 (permalink) Old 11-19-2010, 10:14 AM
Quoted: 118 Post(s)
I run at least 32psi front and rear, radial tires. On long trips with a full load, I run 36-40 in the rears and 35 in the fronts.
tire pressure tamerlane57 Wheels and tires 10 06-07-2019 10:01 PM
What tire pressure? AlanSr Wheels and tires 9 11-19-2010 01:07 PM
Tire Pressure? 2006GTOLS2 Service, Maintenance and Technical Discussion 13 11-13-2005 02:04 AM
Attn: TIRE PRESSURE!! bemeyer 2004-2006 GTO General Discussion 16 05-07-2005 06:23 PM
Tire Pressure Alert!!! LarryM 2004-2006 GTO General Discussion 41 12-10-2004 01:02 PM
