Tire size - Pontiac GTO Forum
post #1 of 18 (permalink) Old 09-13-2013, 10:33 PM Thread Starter
Tire size
Hi, I am picking up my car next tuesday (69judge clone) anyway, I was wondering abut tires. If they are crap and need to be replaced, I was wondering what other widths would work with the rally wheels. Something with a little more meat, but no rubbing issues works. I did it on a tire calculator, and 225 70 14 is pretty mch bang on diameter as the factory 215 75 14. Would 235 even fit on the rear or is 225 the biggest with no issues
Darth Menace is offline
post #2 of 18 (permalink) Old 09-14-2013, 07:28 AM
Oldeboy's Avatar
I have 14" Rally wheels as well. From my searching last fall the largest (widest) I could go was 225 on my 14" rims. (would liked to have gone a little wider)
You may have to go to a larger rim.
Oldeboy is offline
post #3 of 18 (permalink) Old 09-14-2013, 04:28 PM Thread Starter
After doing the wheel calculator there isn't a 235 made that is near equivelant to the diameter of the 215/75/14 tire. The 225 70 14 looks to be the safest bet for fitment and diameter. not much difference of width really to give any better traction though
post #4 of 18 (permalink) Old 09-14-2013, 04:55 PM
Here are the calculations on a 235mm tire with both 60 and 70 aspect ratios;
Tire width,
235 X .03937 = 9.25"
Aspect Ratio 60 series
9.25 X .60 = 5.55" sidewall height
Tire height
5.55 X 2 + 14" wheel size = 25.1"
Aspect Ratio 70 series
9.25 X .70 = 6.47" sidewall height
Tire height
6.47 X 2 + 14" wheel size = 26.9"
A 9.25" wide tire will work on our cars as long as the backspace is correct, the 60 series at 25.1" tall should not have rubbing issues and the 70 series may be too tall at 26.9"
The wheel width needs to be 6.5" to 8.5" wide, BFGoodrich has the TA radial in 235/60R-14
05GTO is offline
post #5 of 18 (permalink) Old 09-14-2013, 06:32 PM Thread Starter
too bad there is no 235 65 14. The 235 60 14 will be 6% off on the speedo....it will show 60mph when your going 56.4. That is significant
post #6 of 18 (permalink) Old 09-15-2013, 05:32 AM
I have 14x7 wheels
Running: 14x7 Rally II 245x60x14
They look great, wide and fit great in the wheel-wells
As far as speedo. TH 400...3.55 rear... Spot on up to about 58 mph then at 60 off by about 2mph. Am using the 45 tooth driven gear I think its the light blue one.
post #7 of 18 (permalink) Old 09-15-2013, 02:37 PM
A 65 series would be a good fit,
05GTO is offline
post #8 of 18 (permalink) Old 09-15-2013, 06:16 PM Thread Starter
Originally Posted by GTO JUDGE View Post
I have 14x7 wheels
does the 245 tire bubble out a lot past the rim? Like look strange or no?
post #9 of 18 (permalink) Old 09-15-2013, 06:57 PM
Pick up some 15x7 rally II's off craigslist and you'll have an almost endless tire selection.
post #10 of 18 (permalink) Old 09-19-2013, 11:36 AM Thread Starter
thanks for the info guys. I got the car and the wheels/tires are crap. I am Canadian so I dont have the store/website options that you do unfortunately. I am thinking of getting these for it: Ridler Wheels - Style 675 Polished, Ridler Rims in Canada.
The tire will be 235, so I assume that is wide enough but not too wide to cause rubbing in the front?
64 tire size? Jimconv64 1964-1974 Tempest, Lemans & GTO General Discussion 16 06-26-2013 04:34 PM
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
what tire size. The Chosen One Wheels and tires 5 06-07-2011 02:29 PM
Tire Size GuatoLT1 2004-2006 GTO General Discussion 4 01-02-2011 01:35 AM
need tire size scy-co 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-23-2010 10:31 PM
