Tire size - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-12-2013, 06:09 AM Thread Starter
MAP53's Avatar
Tire size
On a 69 with stock ride height can you run 235-60-15 tires with out any rubbing issues using 15x7 wheels? The 69 I am buying has the 14" wheels with red line tires. I am thinking about trying to go with a 15" set up but not sure if it will all fit.
Mark
MAP53 is offline
post #2 of 5 (permalink) Old 11-12-2013, 07:59 AM
SANDU002's Avatar
The setup you plan to use will work.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 5 (permalink) Old 11-13-2013, 11:11 AM
That's what I'm running on my 69. Now and then in tight turns, the outside edge of the tire will just kiss the lower edge of the front wheel opening. It hasn't been frequent enough or bad enough for me to actually DO anything about it, in fact I usually forget about it until I'm driving the car and it happens...
They say the memory is the first thing to go when you get olde. I forget what they said the second thing is....
post #4 of 5 (permalink) Old 11-13-2013, 11:32 AM Thread Starter
MAP53's Avatar
Tight turns as in when parking or such at slow speeds and not while normal driving? If so that should not be a issue. I have a almost new set of 235-60-15s and figure I can buy a set of 15" wheels and use them. I have a Boss 302 in the back of the shop they would fit but it might be years before I get around to doing it. I'm thinking either a set of 15" rally IIs or possibly the old school Keystone mags. I think either would look good on the GTO with the white letters.
MAP53 is offline
post #5 of 5 (permalink) Old 11-14-2013, 02:58 PM
kilkm68's Avatar
I had the 235/60/15 on 7in Cragers on the front of my '68 and would get some rubbing occasional when I would cut the wheels hard when backing. I ended up selling them and went with the skinny 205's on a 6 in crager on the front and the wide 275 on a 8 in crager on the rear, I like the look, Goodyear Eagles. The 235's on the front were just a minor problem.
kilkm68 is offline
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
Tire Size GuatoLT1 2004-2006 GTO General Discussion 4 01-02-2011 01:35 AM
need tire size scy-co 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-23-2010 10:31 PM
tire size Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 01-02-2009 07:28 AM
help tire size? gtony Wheels and tires 0 06-04-2006 12:38 AM
