Tires -Stance of 66 GTO - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-21-2014, 10:20 PM Thread Starter
Please submit photos of your GTO's using 60 series tires on back and 70s series tires on front. Please indicate the size tires/wheels you are running. Trying to switch to wider 60s tire that doesn't affect the original stance of the Classic Look! Thanks!!
ottfive is offline
post #2 of 8 (permalink) Old 08-22-2014, 12:09 PM
Quoted: 103 Post(s)
Here's a photo of a friend's '67 with 245/60/14's on the back, and 70's up front.....
Name:	Chip One 417.jpg
post #3 of 8 (permalink) Old 08-22-2014, 04:05 PM
ottfive,
60 and 70 are actually the aspect ratio and determine the sidewall height, Here is a breakdown of a 245/60/14 tire;
245 x .03937 (metric conversion)= 9.645" tire width at the widest point,
9.645 x .60 (aspect ratio)= 5.78 sidewall height
5.78 x 2 + 14" wheel = 25.56" tire height,
05GTO is offline
post #4 of 8 (permalink) Old 08-22-2014, 09:32 PM Thread Starter
Looks Great!!!!!
ottfive is offline
post #5 of 8 (permalink) Old 08-22-2014, 09:39 PM Thread Starter
So I'm currently at a 205x75x14 tires on back giving me 29 .3 tire height? so this would change my effective rearend ratio of 3.55 by going to a smaller tire height? Thanks for the info.
ottfive is offline
post #6 of 8 (permalink) Old 08-23-2014, 09:35 AM
"Shorter" (smaller diameter) tires have the effect of slightly lowering (numerically increasing) the gear ratio, "taller" (larger diameter) tires have the opposite effect.
You can calculate the differences if you know "all the numbers": current gear ratio, current tire diameter, "new" tire diameter.
post #7 of 8 (permalink) Old 08-23-2014, 12:00 PM
Quoted: 103 Post(s)
The main thing here is to get the offset of the rims correct, so that whatever tire you use, it doesn't rub into the fender well. Nothing more 'hack' than seeing wheel wells cut or hammered out to clear ill-fitting wheels.
post #8 of 8 (permalink) Old 08-23-2014, 01:07 PM Thread Starter
I agree no cutting will be done, I'm looking at 225x70x14 front and 225 or 245 x 60 x14 on rear my wheels are cragers 14x7. Thanks!
ottfive is offline
Tires for a 68 GTO. JESchulte 1964-1974 Tempest, Lemans & GTO General Discussion 7 06-23-2017 06:24 PM
Adjusting the stance/ride height Ace 1964-1974 Tempest, Lemans & GTO General Discussion 8 03-11-2014 06:16 PM
fresh new stance / need wheel tire advice harp 1964-1974 Tempest, Lemans & GTO Wheels & Tires 3 04-24-2012 07:10 AM
1969 stance? jimchevy 1964-1974 Tempest, Lemans & GTO General Discussion 10 01-29-2012 05:47 PM
Best Tires for the GTO asteng88 2004-2006 GTO General Discussion 12 05-09-2005 10:20 PM
