Torque Specs - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-08-2006, 10:07 PM Thread Starter
Torque Specs
Im putting a new ram premium replacement clutch in my dads 66 with a 389 and 4 speed and i was wondering what torque specs for the flywheel to crank, Pressure plate to flywheel, and any other tourque specs i will need for this. I have 3 restoration guides and i cant find this info any where.
toms66 is offline
post #2 of 2 (permalink) Old 01-09-2006, 08:18 PM
lars's Avatar
Tom -
All the torque specs are in the Factory Service Manual. The manuals are available from all of the GTO Restoration Parts suppliers.
Correct torques are:
Flywheel to crankshaft: 95 ft/lbs
Pressure plate to flywheel: 25 ft/lbs
Bellhousing to engine block: 40 ft/lbs
Clutch fork ball stud: 40 ft/lbs
Transmission to bellhousing: 55 ft/lbs
Countershaft stud to engine block: 28 ft/lbs
Countershaft stud-to-frame bracket lock nut: 20 ft/lbs
lars is offline
