Traction Bars - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-06-2010, 03:57 PM Thread Starter
Traction Bars
I've been looking at these trailing arm braces and anti-hop bars and I am not sure where they go or if they are difficult to install. Help?
'81 Regal, Daily Driver.
'69 GTO, Lifelong Project.
'91 S-10, Auto-X Project?
liljohn442 is offline
post #2 of 7 (permalink) Old 11-06-2010, 04:01 PM
Do you have pictures?
05GTO is offline
post #3 of 7 (permalink) Old 11-06-2010, 04:04 PM Thread Starter
post #4 of 7 (permalink) Old 11-06-2010, 06:03 PM
crustysack's Avatar
the webpage you listed has an instruction page that shows installation of these items- if you can not follow the step by step instructions listed then I would not buy them
crustysack is offline
post #5 of 7 (permalink) Old 11-09-2010, 11:03 AM
The anti-hop braces essentially raise the location of the upper controll arm bushings in the rear-end. They straddle the front side of the differential and bolt onto the upper bushing.
The trailing arm mount brace just triangulates the frame section and adds a bit of stiffness and helps prevent and stress cracks in the frame.
These are all very easy installs but I would not expect any drastic changes in handling.
Keitha is offline
post #6 of 7 (permalink) Old 11-18-2010, 01:41 PM
The braces are more for strength/safety. They connect the front mounting point of the lower to the front mounting point of the upper control arm to reduce flex, mostly in the upper control arm mounting points on the crossmember. Some GTO's had similar connectors from the factory, as GM recognized this as a potential problem area.
The hop stop bars essentially relocate the rear mounting point of the upper control arms "higher" to change the angle they make, resulting in moving the suspension instant center towards the rear of the car. Supposedly this helps control wheel hop (are you experiencing wheel hop?) but it also negatively affects the leverage that's used to "plant" the tires on a hard launch. Wheel hop can also be caused by any combination of loose/worn suspension bushings, weak shocks, or incorrect pinion angle. Speaking of pinion angle, moving the suspension mounting points around is an opportunity to disturb it, leading to driveshaft vibrations and other problems, so be careful and make sure you measure your pinion angle both before and after installing these, if you do.
Of the two jobs, putting on the hop stop bars will be the most difficult because if the location. If you leave the rear end in the car, make sure to do them one at a time if you can, always having at least one upper control arm (and both lowers) fully connected at all times. Otherwise the rear end housing is bound to rotate on you some and you'll have to use some kind of leverage to get it back into position. You'll want to support the car by the axle so that the suspension stays compressed. If you support it by the frame and let the suspension 'droop', you'll find it difficult to get the upper control arm ends loose because the geometry of everything tends to try to twist the ends of the arms at the bushings putting them in a bind. If you choose to remove the rear end (which makes installing the arms easier) then you'll have to deal with disconnecting brake cables, brake lines, bleeding brakes, using multiple jacks and a helper or two to get things lined up again so you can install the bolts... There are advantages and disadvantages to both methods. It's not all that hard, really, if you take your time - but if you've never done something like this before I'd plan on it taking a full Saturday at least.
So, the braces are probably a good idea and they aren't all that hard to install. The hop stop bars, eh... I'd consider them only if I was experiencing bad wheel hop on launch and had tried everything else to correct it first.
But that's just me.
post #7 of 7 (permalink) Old 11-18-2010, 04:50 PM
66tempestGT's Avatar
unless you have some worn parts wheel hop shouldnt be an issue. the a body rear suspension is a pretty good design for straightline launches. leaf spring cars are the ones prone to wheelhop because of spring wrap up.because of this thread and a similar one im getting my wife to scan a pic of my 64 elcamino pulling the left front with 100% stock suspension.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
Traction control, still no traction :-) tummen 2004-2006 GTO General Discussion 14 08-22-2008 12:25 PM
GTO Sway Bars? AlaGreyGoat Drive train, suspension, alignment and brakes. 3 02-21-2008 02:32 AM
Talk to me about Sway Bars Chris Draper Drive train, suspension, alignment and brakes. 6 01-21-2008 10:06 AM
Harness bars goat boy Racing and Kill Forum 0 08-17-2005 08:31 AM
latter bars lugnut 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-14-2005 07:43 AM
